Question about Lexmark X4650 InkJet Printer
Ocr folder Is the ocr folder in my lexmark x4650 installation cd? when I try to scan it tells me to install ocr software.
    Problem Solver:
  • 14 Answers
The software you need is Abbyy Sprint OCR. If it's not installed, I suggest running the printer setup again, making sure it's selected when you get to the software list. Perhaps you unchecked the box when you ran the installation the first time, or didn't know what it was and uninstalled it from your computer. You may be able to find it by hunting through the CD, but it will probably be easier to run the setup again.
Posted on Jan 19, 2009
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
How do I download and install ocr for Lexmark 4000 series
Jan 20, 2012 | Lexmark X4650 InkJet Printer
I need OCR folder for lexmark x4530
You can download and install the Lexmark OCR scan software using the installation disc that came with your printer only. The software is not available for downloading online.
If you lost the disc, please contact Lexmark Technical Support Center to request for one. Thanks.
Nov 11, 2011 | Lexmark X4530 InkJet Printer
I got a new pc windows 7 64bit and do not have the CD or direct cable for my all in one lexmark x4650. It will print for me but I can not scan. I would like to be able to scan and save stuff pictures...
For scanning your documents or you letters, you will need the OCR software that is available only in the install disc for your printer. Please contact Lexmark technical support for assistance on this matter.
Mar 23, 2011 | Lexmark X4650 InkJet Printer
OCR folder not found after installation of driver (software) for Lexmark X4650
The Lexmark OCR scan software is available in the installation disk. The OCR folder should appear when you Explore the disk (for Windows) or Show Package Contents (for Mac). Open the executable file to manually install the software. If you don't have the installation disk, contact Lexmark technical support for assistance. Thanks.
Oct 11, 2010 | Lexmark X5470 All-In-One InkJet Printer
I can't scan on my lexmark printer model x5650. When I scan a document it gives me the message " Install the OCR from the OCR folder". I can't find the OCR folder in my computer. What should I do".
The Lexmark OCR scan software is available in the installation disk that came with the printer. You can explore the installation disk and look for the Abby setup application in the OCR folder (for Windows). For Mac OS, right-click on the Install icon and choose Show Package Contents. Open Contents folder > open Package folder and manually install the Abby Finereader application.
However, if you don't have the installation disk, contact Lexmark technical support. Thanks.
Sep 30, 2010 | Lexmark X5470 All-In-One InkJet Printer
I've lost my set up cd and although the printer and copyer work I cannot scan a document onto the computer.
Scanning a document to your computer may require the Lexmark OCR scan software which is only available in the installation disk. Try to contact Lexmark technical support to request for the installation disk. Thank you for choosing Lexmark.
Sep 15, 2010 | Lexmark X4650 InkJet Printer
LEXMARK PRINTER X4650 OCR folder not found
The scan software(OCR) may not be installed in the computer or probably got corrupted. Reinstall the software. The Lexmark scan software(OCR) can only be installed using the installation cd that came with the printer. It's not available online for download since it's a big file. If you don't have it or you lost it, I suggest you contact Lexmark Technical Support for assistance.
May 03, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lost installation disk for my Lexmark x1240 all in one printer. I'm trying to scan a text document to edit but tells me I need to download/install OCR software in the OCR folder on that disc. Possible to...
go to this site http://downloads.lexmark.com/perl/downloads/downloads.cgi
put in your country etc.......
choose the x1240 in the driver box.......then search
choose windows vistamag-glass_10x10.gif from the operating dropdown box.......
click on download now and then install the new driver.....
hope that helped
Oct 19, 2008 | Computers & Internet
Lexmark X4650 InkJet Printer Logo
1,119 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
