Question about GE WCVH6260FWW
GE WCVH6260FWW Washer replace drive belt - GE WCVH6260FWW
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I need to find a user's manual for #wcvh6260fww GE frontload wash
Here you go.
http://genet.geappliances.com/DocSearch/Dispatcher
Good Luck and Please Rate FixYa!
Posted on Jan 10, 2009
SOURCE: ge fornt load washer mod #wcvh6260fww the inner
I'm having a similar problem. Mine sounds like there is something behind the drum, like maybe a coin or loose nut? It screeches horribly.
Posted on Aug 09, 2009
  • 298 Answers
SOURCE: My GE washer wcvh6260fww wont drain. also the
yes i would go to this web site and they can help u in the matter )appliauce repair plant.vstore.ca
Posted on Dec 01, 2010
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
How to repair drive belt on GE Profile washer
Contact the GE Washer div. and request a schematic of the machine. It will show you the detailed format for removing parts and construction teherafter.
Mar 25, 2014 | GE Profile WPRE6150KWT Colossal Capacity...
WCVH6260FWW drum sticking
you have an item in between the inner and outer drums if you take the heater unit out you should now be able to see it remove it
Jan 10, 2014 | GE WCVH6260FWW
Ras7233kq0 washer won't spin Washer agitates and
Check the belt on the drive system to the motor.if the motor is working the belt might be broken. If the belt is intact it could be a relay to engage the belt drive.
Oct 16, 2013 | GE WCVH6260FWW
Washer does not spin. when it should be spinning it buzzes. I gave the tub a push start and it did rotate slowly. the washer does rotate for washing
Possible that the drive is jammed or the motor is faulty , the voltage to the motor is low. If there is a capacitor to the motor then the capacitor can be weak and might result in slow start.
Nov 01, 2010 | GE WCVH6260FWW
I have a front loading GE wcvh6260fww that will fill with water, but will not agitate or spin out the water...thus, no washing of clothes regardless of cycle selected. The timer counts down and the water...
probably a bad door switch, if you can take the door or top off and find the wires running to the switch take the wires off theswitch and plug them together by wrapping electrical tape around them and then try the washer. If that dont work may be a bad control board
Sep 03, 2009 | GE WCVH6260FWW
Getting the door off the front loading washer (GE)
Already solved.
check :-
http://www.fixya.com/support/t1456712-ge_frontloader_door_gasket_ripped
Thanks
Jun 13, 2009 | GE WCVH6260FWW
GE WCVH6260FWW Logo
56 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
