Question about MSI RS482M4-ILD Motherboard
No signal PC starts up (fans running etc) but no signal to monitor. 2 short beeps but tried interchanging all 4 memory sticks without success. Tried a different monitor.
  • 1602 Answers
SOURCE: MSI P7N Diamond board memory problems
this may be a bois issue and you have to go in and make changes to the spd file, epp, xmp, according to an articale i was reading that the guide line setup by the jedec group allow the motherboard manufacture set it up to 800 and anything over 800 will not be recongnized because there is no standard out there the company can go in and change the bandwidth or tweak it and say there chip can produce 1300mhz and the chip may produce 1333mhs, also can go in and adjust the temp. of the cpu and that will change the speed also.
the memory slots on the motherboard are the most important and that is where you want the most ram it can support in the motherboard configuration, when you start trying to use slots 3 and 4 your are making the machine work harder than it should have to. lets say you have a board that allows 4gb per slots and you can use 1 or 2, or both shots you are going to get the best performance with the lesser amount of curcuitry the system has to use, lets say you have motherboard that supports 4 dimm slots and you put 1gb per slot your machine will do 4x more work and slow your system down 4x or even 4fold,
some company are going to tell the custome what they want you to hear. just look at the speed performance over all, more conponet more work for the machine to perform, less componet better performance, memory 1 stick or 4 sticks, just think.
if you are sharing you vedio memory than add 1 gb on top of you system ram.
i have hp notebook it cam with 2gb ram and it can share up to 800 mg vedio ram, so the manufacture said you can either run 3gb or 4gb of memory, the cost between 1 stick of memory pair of match one were about the same price, hp price was about 100.00 dollars, that 100.00 dollars each peace.
kingston same memory memory bought for hp computer manufacture and they put there label on it. kingston memory matching pair or set # are inseqaence or following numbet sets were about 69.00 to 75.00 lifetime warrenty threw kingston verses hp one year from date of purchase.so i got 2gb x 2 chip total of 4gb daul channel memory.
go on line compair pricing with other venders
memory.com or type in memory chip in theinternet address bar.
anything over 800 mhz is being considered overclocking.
anything you push beyond the normal operating speed is going to be considered overclocking and void on part from the manufacture so is it worth overclocking to shorten the life of your product.
candymangandy
Posted on Feb 11, 2009
ubelong2matt
  • 67 Answers
SOURCE: Bios Beeps during reboot
According to the information at:
http://www.pchell.com/hardware/beepcodes.shtml
AMI beep codes of 1 long and 3 short are, in fact, correctly identified as memory errors. One thing to note is if this memory is Dual Channel, you can only install the memory in groups of two. You must first fill DIMM slot 1 and 3 before filling DIMM slots 2 and 4.
The below website has much more information about your particular motherboard and there's a note about some JEDEC setting for memory that you might want to watch out for or disable to see if it improves stability.
http://www.msicomputer.com/product/p_spec.asp?model=K9A2_CF-F_V2&class=mb
As for Windows XP 32-bit not recognizing more than 3.5 (at most) memory, this is unavoidable. To see all 8 GB, you would need a 64-bit version of Windows. This is something that cannot be altered by BIOS or memory choices, unfortunately. Feel lucky in the fact that you have XP Pro as XP Home will only recognize up to 2.5GB. You'll never utilize all 8GB unless you upgrade your OS, so keep that in mind!
Posted on Mar 04, 2009
c-tekk
  • 177 Answers
SOURCE: no post to bios on new pc build
FIRST....... Make sure you remove the stock thermal compund (pasty/sticky stuff) from the bottom of the heat sink as well as from the top of the cpu.........
Second APPLY some ARCTIC SILVER 5 compound-ust a thin coat of it over the top of the cpu......use an old credit card.....keep it ff the sides and bottom though......it's important not to use too much........one little tube will do anywhere from 3 to 5 CPUs...!!!
(stock thermal paste/thermal compunds......**** BADLY and can cause a cpu to burn up)
reseat (properly) the cpu and carefull
Now make sure you're 24 pin or 20+4Pin Power connectors are connected, as well as your fans..........disconnect all your SATA Devices, and remove everything but the video card , CPU, and fans.......Now it should post (if all your jumpers are set correctly...........
IF it still doesn't post, remove the video card and reboot.
If it doesn't beep at all......... You have one of 2 things.........A DEAD CPU, or a DEAD MOBO
Posted on Mar 19, 2009
sparky1500
  • 1066 Answers
SOURCE: POST problems or XP Stop 0x8E
run memtest 86, test each ram stick, if it shows both as bat, then your mobo;'s memory controller is bad. if neither is bad, then it is your graphix card
Posted on Jul 01, 2009
  • 105 Answers
SOURCE: NO SIGNAL TO MONITOR
change the memory card, then reset the cmos. if problem persists change the video card, its probably bad.
Posted on Sep 19, 2009
Packard bell imedia d3318 no vga signal
It is the video graphics card, or the motherboard, but you can sub out the ram memory one at a time as you test. It might be a bad stick of ram which would rule out the above mentioned
Apr 10, 2012 | Packard Bell iMedia Computers & Internet
Well first its kind of the same problem but idnk wats wrong everything is new and built from scratch but nothin... it turns on fans spining and etc. but no turn on beep no boot to bios or nothing jus sits...
Hello
No beep?
1 Start with making sure all conections are correct,hard drive,dvd,cd,floppy.
2 Check that processor is mounted correctly,remove and do over.
3 Also processor fan.And heatsink.
4 Memory sticks,remove and put back in firmly and secure.If you have 4 memory slots and 2 memory sticks,seperate them.Most slots are color coded white blue white blue or whatever color you may have.So if you have 2 memory sticks put one in white slot,and the other in next white slot.
Im betting you have either processor in wrong or memory in wrong.
Jan 13, 2011 | Computers & Internet
Here is my problem, a bit long but almost the complete story! I have 4 year old MESH X-Treme FX60, running XP2. It has an ASUS A8N-SLI Deluxe PCI-Express Mainboard, 2 Serial ATA Hard drives and (according...
Remove everything connected to the PC ie usb devices with the exception of keyboard and mouse. Removing memory and starting a PC will never work it needs it to boot. check all connections are secure especially that the graphics cards are seated in their slots, now try.
The error code you get is related to the graphics card so remove them and clean them up refit and try again. If it still fails remove the link between the cards remove the card you suspect as faulty and boot with just one card. When you find the culprit you can choose to live without it or get it repaired. If you are not into powerful 3D effect games I'd live without it
Jan 06, 2010 | ASUS A8N-SLI Deluxe Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Dell 4600 no monitor signal
Hey Tony,
If you haven't already: pull all pci cards:
If you pull the ram, and you get no beeps at post, it's likely the main board. Does the pc beep at all? with or without ram? If not, likely the main board. Sorry. Hope this helps...
Aug 17, 2009 | Dell Dimension 4600 PC Desktop
My Emachines_w2888 will not boot up. I get a, (NO SIGNAL INPUT).
If all you have done is upgrade the memory, take out one stick of memory and see if the computer will start up. If it acts the same way it has been acting, take out the other stick of memory and put the first stick of memory back in. You could have a bad stick of memory. Does the computer make any beeping noises when you try to start it? Those beeps are the BIOS way of telling you there is a problem. One BIOS beep means the system is starting if you have more than one beep, there could be a problem, the number of beeps along with the brand of BIOS will give you a clue as to what the problem is. Once you know the number of beeps and the brand of BIOS you can search the Internet for what the problem might be. Your monitor showing "NO SIGNAL INPUT" is its way of saying "I'm ok but something else is wrong".
Good luck
Nov 11, 2008 | Computers & Internet
Continuous Beeping, new PC
Hi.
Continues short beeps... means a short OR no power OR loose card OR system board.
Test it without the keyboard and mouse too. Just the Processor with heatsink, motherboard, memory and Video card.
Now add the keyboard, no mouse yet.
Check also the voltage of the CMOS Battery it should be 3V.
keep me posted for the result... count also the beeps.
Feb 09, 2008 | Intel Motherboard
Monitor says no signal
cheak ram u can get power 400 watts highter atx style with 2 rails but might be bad video card or it defulted to other slot
Jan 25, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Not booting, i mean even getting past post.
how many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Oct 21, 2007 | Intel Motherboard
MSI RS482M4-ILD Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
