Question about Gaggia Baby Espresso Machine
GAGGIA BABY. NO WATER COMING OUT.STEAMER FINE
I TOOK MACHINE APART SEEMS PUMP IS OK. NO AIR LOCK COZ STEAMER WORKS FINE. CANT WORK OUT WHERE IF AT ALL THERE WOULD BE A BLOCKAGE. MACHINE HASNT BEEN USED IN LONG WHILE
  • Anonymous Jan 26, 2009
    I have exactly the same problem. Any helpful tips out there?
  • Maurice Neal
    Maurice Neal Apr 01, 2014
    Switch it on, pick it up and shake it. Worked a treat on mine having spent hours trying everything else
    Problem Solver:
  • 5 Answers
I had exact same problemeven took entire machine apart - all fine. Solution is very simple... descale with Gaggi descaler solution. Remove filter and block, mix solution with 1.5L of water, turn on for 20 seconds, wait 20 rinse through steamer, wait 3 minutes and repeat until all solution used - rinse compeletly with clean water
Posted on Apr 25, 2009
    Problem Solver:
  • 13 Answers
Buy a new coffee machine or replace filter
Posted on Jan 19, 2009
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Water dripping not running when making coffee
First question:Are the rest of the machine still working correctly?
Second question:How was the waterflow before descalling?
Here are short description on how most of these machines work.
It will have a cold water reservoir for filling with cold water with some sort of water full sensor, it will then be followed with a high pressure pump.which are used to fill the boiler.After the boiler it will then go out to your to disspencers.in your case the steamer and one for coffee.The outlet at the boiler will propably be split in two by using valves.
To come back to your problem i assume it had a waterflow probleme before you descalled.When you are descaling your machine their are some times pieces of scale that is not propably disolved by the descaling process which will get stuck in the pipe work acting as a valve
causing waterflow problemes.
The other probleme might be that your water dispencers valve might be faulty either by a poor supply(power) or the sollenoid is starting to size up.
Just switch of the machine when taking of any covers you are working with water and electricity which do not mix well
Mar 26, 2012 | Gaggia Baby Espresso Machine
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
No water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Jun 18, 2009 | Gaggia Baby Espresso Machine
Gaggia baby dose d (circa 2007) wont dispense water? pump?
Sounds like it needs descaling - not the normal descaling but inside the pump head!
Oct 25, 2008 | Gaggia Baby Espresso Machine
Pump problem on a Gaggia Espresso Evolution
You need a bellows pump or similar, when you start the pump you need to set the pump to the water inlet and press in the water with force.
Jul 09, 2008 | Gaggia Evolution Espresso Machine
New gaggia baby class "d" espresso mch
it seem the pump is not prying itself you have to inject water try with a turkey blaster the pump to put juice on a turkey fill it up with water start the machine inject the water in the water hole try that out let hope it work if not you have warranty good lock
thanks for using fixya
pierre
Feb 28, 2008 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
1,213 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
