Question about Mitel 5212 IP Phone
During a call, is it possible to mute? - Mitel 5212 IP Phone
  • tere13 Jan 19, 2009
    Thanks for the info, however I have the 5220 model and I do not have that microphone(image) button on my phone.
    Problem Solver:
  • 13 Answers
How do I put it on speakerphone?
Cricket Samsung Galaxy Grand Prime: Speakerphone:
1. During a call, tap Speaker to turn speaker ON
2. Tap Speaker again to turn speaker OFF
3. Tap Mute to mute the call
4. Tap Mute to unmute the call
see interactive map here that indicates where the Speaker icon is during the call
Using the Speakerphone
Jan 12, 2016 | Samsung Cell Phones
Why when I phone some one I can hear them but they cant heat me
You may have accidentally pressed the Mute button. Undo as below
Mute a Call:
You can talk to someone nearby without letting the caller hear you during a call. During a call: Press <C> t o mute the microphone and "MUTED" will display on the LCD.
Your caller cannot hear you. Press <C> again to unmute the microphone.
Nov 19, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Where is mute button on blackberry curve 8520?
On the top of the phone.
To mute during a call, press the Play/Pause/Mute key on the top of your device.
To turn off mute, press the Play/Pause/Mute key again.
May 09, 2014 | RIM BlackBerry Curve 8520 Smartphone
I have accidentally muted my phone, how do I unmute it. Razzle phone
Knowing the type of phone you have would help also the circumstance. Is the phone muted during calls? or is it muted all the time? If the phone is muted all the time use the volume button usually on the side of the phone to raise the volume and it should take the mute off. If the phone is muted during a call their is normally a button on the screen of the phone during the call to mute and unmute the phone.
Jul 15, 2011 |
My amps stays in the clip mode where as the light on the two channel stays red
Page 7...
CLIP: red, to the left of each Gain control.
Normal indication: illuminates whenever the amplifier is driven beyond full power. The LED's brightness indicates the amount of distortion. Distortion that causes only brief flashing may not be audible.
During muting, the indicator fully illuminates. This occurs during normal "On-Off" muting.
Abnormal indication:
•Bright red illumination while the amp is being used indicates either thermal muting or a shorted output.
•If the amplifier overheats, the fan will run at full speed, and operation should resume within one minute. Allow the fan to run, and make sure the amplifier ventilation is adequate.
•A shorted or overloaded output circuit will cause excessive Clip flashing and possible overheating.
•If distortion is audible without a Clip indication, the problem is either before or after the amplifier. Check for damaged speakers or overloaded signal source. The amplifier Gain control should be in the upper half of its range to prevent input overload.
Jan 29, 2011 | QSC RMX 4050HD 2Channel Amplifier
Trying to install my microsoft LX 3000 headset software...gets to step 2 in install and it says..."not connected to the internet..connect to internet and try again...."...I am on my laptop that is always...
When i'm using Microsoft Lx3000 headphone, the mute switch automatecally ON during call conversation through net. when its on mute button; that time not possible to switch off of mute button same time; there is only solution release the USB and fix again..... and the problems continue during call conversation... why..? how to solve the problem ?
Oct 16, 2009 | Microsoft LifeChat™ LX-3000 Headset
To mute the ringing tone, select Silence. Then either answer or reject the call.
you can also mute sound during call.
Mar 05, 2009 | Nokia 8800 Cellular Phone
Is there a mute option while I am on a call?
The mute button is the top right button, it's a clear colored button. When it's lit and orange it's muted.
Jan 19, 2009 | Mitel 5212 IP Phone
Microphone isn't working on my hs850
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.possible you are experiencing this . i did
Dec 06, 2008 | Motorola Mobility HS850 Consumer Headset
Can't turn off mute on panasonic phone
[Mute /Auto Answer] is a dual function button.
Mute flashes when it is on and Auto Answer lit solid. Both of these features toggle on and toggle off. Auto Answer will turn on and off during the on-hook condition. Mute is employed during call.
If these lights are not associated with the Mic working, you may have a bad set.
Jan 05, 2008 | Panasonic KX-T7453 Corded Phone
Mitel 5212 IP Phone Logo
107 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
