Question about Amana Dryers
Dropped something under lint trap and now drum won't turn
My infant lifted the lint screen out of my amana front load dryer and dropped a toy down underneath the drum. How can I access below the drum to retrieve it ? The drum won't turn now. Thank you, C.
  • 131 Answers
SOURCE: maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Posted on Mar 31, 2008
SOURCE: Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
Posted on May 18, 2008
aborcass
  • 2651 Answers
SOURCE: Small plastic toy down lint trap
is the lint filter on the top of unit??? if so you ll need to disconnect power remove the 2 phillips head screws under the lint trap holding it to the main lid. then after removing about 10 1/4in screws from back panel you ll see a metal sleeve running down the back of the unit( the lint filter actually slides in to it) ending in a circular shape below. remove perhaps 4 more screws holding that panel on and youll gain acess to retrive whatever has fallen down there. easy enough to do yourdself no need to call in a professional
Posted on Oct 23, 2008
  • 89 Answers
SOURCE: Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
Posted on May 26, 2009
SOURCE: Ge Adora Dryer, Worked great.
the dryer during its cycle squeaks and rumbles it sounds like some thing is not right.
Posted on Jan 03, 2010
My amana LE9207w2 has been taking longer and longer to dry the clothes. I clean out the vent regularly... when I use it a lot, it shuts down for hours. Now it stopped altogether with wet clothes insid
First the dryer vent should never go out of the roof thats just asking for trouble. The dryer has to work harder to get the air out. any lint that would be in the vent when the dryer shuts off just comes back down instead of being blow outside. there is probably a buildup of lint around the exit pipe on the roof. As far as your problem either you have a bad motor or there is something stuck in your blower wheel. the best way to check this is to reach inside your dryer and try to turn the drum. If your drum spins freely then hold the door switch and push the start button keep holding the door switch the dryer will be buzzing now turn the drum if it starts to go after you push the drum then you have a bad motor. If the drum does not spin freely then you probably have something stuck in your blower wheel
Aug 26, 2012 | Dryers
My dryer is about 3 years old suddenly won't dry a load in one cycle. Recently moved and moved the dryer with. Haven't had any problems.
I have included a link to the pictures of the routing of the belt.
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 15, 2011 | Kenmore 500 6952 Dryer
I have a 240volt whirlpool driyer and the drum won't turn. I want to take the back off to see if I can see a belt or something. Any advice? I'm afraid the four screws in the center of the back will...
Installing the belt
facing down.
Please RATE me
Jan 13, 2011 | Whirlpool Dryers
Dryer drum not turning
Installing the belt
facing down.
Please RATE me
Jan 06, 2011 | Whirlpool Dryers
I have a cloth belt off that goes be hind drum. how does this go back on.
I included the routing of the belt, go to this website and find your Amana.........http://www.applianceaid.com/images/belt-config.JPG
Installing the belt
facing down.
Please RATE me
Jan 06, 2011 | Amana NED5200TQ Electric Dryer
Why won't my Dryer tumbler turn with heavy load?
Your belt is almost worn out...replace you belt
I will give some instructions on how to do this, plus include a drum belt configuation link to show you how to make your new belt work right
Installing the belt
facing down.
Please RATE me
Jan 06, 2011 | Maytag SDE3606A Electric Dryer
Drum will not turn-it just hums
Installing the belt
facing down.
Please RATE me
Jan 02, 2011 | Amana NDG7800AW Gas Dryer
When start button is pushed there is just a "clicking" sound and nothing else.
Installing the belt
facing down.
Please RATE me
Dec 29, 2010 | Amana NGD5200TQ Dryer
Dryer wont turn, just "humms"
Installing the belt
facing down.
Please RATE me
Dec 21, 2010 | Whirlpool Dryers
Amana dryer Ale643RBW How do I Take Apart to replace belt
Installing the belt
facing down.
(http://www.applianceaid.com/images/belt-config.JPG)...Belt routing diagram.
Please RATE me
Dec 19, 2010 | Dryers
Dryers Logo
20 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
