Question about Whirlpool GGQ8831L Gas Dryer
Dryer runs but no heat
If this is a thermal fuse problem, where can I purchase one? Home Depot or Lowes?
    Genius:
  • 2,920 Answers
Go to lowes they should sell what you need
Posted on Jan 19, 2009
If i am on the right track, the thermal fuse in our Frigidaire Affinity dryer is bad. Model number is faqe7011kwo. where is the thermal fuse located and can i get 1 at a local hardware store (Lowes
You cannot purchase this item at any home store as it is only available thru the distributors of appliance repair components. Your best opportunity would be to purchase it from www.appliancepartspros.com . You can also see where it is located on your specific model by looking it up on the parts breakdown exploded view (normally on the blower outlet). If you can't figure out how to maneuver thru the diagrams, that would be a sign that you should contact a qualified service company to complete the repairs for you. Otherwise, you will have no trouble with the repairs if the troubleshooting was done properly.
Jan 01, 2015 | Frigidaire Dryers
Need picture of thermal fuse to Samsung front load dryer
It should look like this one or a little bit bigger / different shape...
Show this picture to someone at lowes or home depot and they should be able to show you where it is...
I hope this helps you...
May 14, 2013 | Dryers
My thermal fuse has blown on my maytag dryer model#6800AWW. How do you release the cover to get to it
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/thermal-fuse-Maytag-dryer.html Hello there, this will help you with disassembly.
Your dryer has two thermal fuses. One is located on the heater box (that contains the heater elements), and the other is on the blower wheel cover.
Right now I'm positing a link of a parts diagram for your dryer. On both links I'll tell you which number the thermal fuse is.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47833&diagram_id=28471886#d28471886 Part number 10.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47833&diagram_id=28471885#d28471885 Part number 11 on the heater box.
To test these fuses, you can buy an inexpensive continuity tester at lowes or home depot. They're really cheap if you get one that just tests for continuity. When you locate the thermal fuse, you will remove one of the wires and put both clamps or test leads on the fuse's terminals. You should have continuity. If it does, that means that electricity can flow through freely and the fuse is still okay. I would check both.
I hope that helps you out. I will be more than happy to help you if you need any further assistance.
My name is Mike, hope your dryer is up and running soon.
Congrats on doing the job yourself. :)
Aug 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a dryer that runs but no heat. I removed the thermal fuse and hooked up a cont. Checker no sound. Is the fuse bad? Can I get a replacement at home depot or Lowes?
the fuses are usually found at an appliance parts store. You can google "whirlpool dryer parts" and find a parts store near you or one you can order from over the internet. I have replaced many of those, and they cost between 20.00 and 30.00 dollars.
Jun 18, 2010 | Whirlpool LGR8648L Gas Dryer
MY DRYER BLOWS OUT COLD AIR INSTEAD OF HEAT, WHAT IS THE PROBLEM? I CLEANED OUT THE VENTS AND IT HAS FULL POWER PLEASE HELP
heating elements out ..they are easy to change from the back of the dryer....you can buy these at lowes or home depot
Nov 08, 2009 | Dryers
I have a kenmore elite dryer for about 4 years and it will not heat up. Can you please help?
check breakers in panel make sure both are in the on possition(home elec. panel)....if thats not it replace both heating elements...they are located on the back usually held in by 2 screws in each one..youll find these at lowes or home depot
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Electric dryer will not heat. Just bought off of craigs list
Chances are thermal protection switch has been tripped.
If you cannot trouble shoot electrical circuits you will need a repairman. Also good be heating element but doubt it.
Switch runs $20.00 to $45.00. Labor you can go to home depot Or lowes & replace dryer cheaper usually.
Hope who you bought from did not know it was broken. :-(
Mar 08, 2009 | Dryers
Whirlpool Gold Electric Dryer.
Hope your sitting down. There is not just heating elements in the dryer there are thermal switches that turn heating elements off & on like your house thermostat clicks off & on. Also there are overheating thermal switches to keep the elements from setting the dryer, clothes on fire. More than likely you overheating thermal switch has tripped, from lent in vent or pinched vent tube or normal failure. Some of these switches can be reset, others replaced. If you can not trouble shoot electrical circuits leave it to repairman. Switch $20.00 to $42.00 Labor service call cheaper to buy cheap new dryer. Could be heating element but most use only one with different inputs for heat. If your getting some heat not likely element.
Micrwave does not heat, and turns off by itself before time
Unplug the Microwave and remove the outer cabinet. Inside the cabinet will be a thermal insulated fuse, looks like the old buss fuses for early model cars but white. Replace that with the correct fuse which can be found at Lowes or Home depot and see if that solves the problem. Be careful not to touch any capacitors if they are in there.
Mar 14, 2008 | Panasonic NN-H664 Microwave Oven
Whirlpool GGQ8831L Gas Dryer Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
