Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Icemaker does not work there is water to it but it doesnt run in
The icemaker has water to sol. valve but won't let the water in its not a bad sol.the rest of icemaker just won't run?
  • Kenmore Master
  • 19,396 Answers
Tryusing an hairdryer or defrosting the unit completely , this often getrid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace thewater valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
Ice maker doesnt work
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
Jun 05, 2012 | Kenmore Side by Side Refrigerator
Whirlpool side by side icemaker won't work
Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
May 27, 2012 | Kenmore Refrigerators
No water flowing to ice maker
to see if icemaker is still good pour a 1/2 cup of water into tray and wait for a day. make sure shutoff arm or switch is on or down (arm down) if it makes ice then the icemaker is ok. if it dont then hold up.
if it makes ice then either the water pressure is too low (or no water) or the water valve is bad. (to check water valve you need a volt meter).
ok back to hold up part... the icemaker actuallys controls the water valve so you can have no water but that doesnt mean the icemaker is bad. so here are the three possiblities to your problem:
ice maker
water vavle
not enough/no water
before you buy anything let me know and we can go over this again
hope this was helpful (or confusing sorry)
Apr 02, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
HOW DO I CHANGE THE WATER FILTER - I BELIEVE THAT THE ICE MAKER IS NOT WORKING BECAUSE OF THIS
The icemaker is probably NOT run through the water filter. Typically the filter is only for the water through the door. Either the water solenoid valve that supplies water to the icemaker is bad or the icemaker is bad.
Mar 03, 2010 | Maytag MFD2561HE Bottom Freezer French...
Whirlpool ed25dq icemaker not working even though
the water valve maybe the problem as it is a dual one,, and if filter moded it has 3 solnoides flow . that control water . ck sol with ohm meter or test cord . . ice maker also works only at 15 deg or lower . so ckk tempt of freezer .. mm
Jan 07, 2010 | Refrigerators
Not getting water to icemaker but have water in door dispenser
no water to ice mker / look at the water valve in the back it is a two sol. valve one side for water and other for ice .. also the tube in back of freezer that fill the ice mker may be frozen .. ( hot water up the tube will open it .. mm
Nov 30, 2009 | Dryers
My ice maker isn't getting water to the tray so isn't making ice. this happened after door left ajar and after I turned it off and cleaned and defrosted it. Is there a fix?
I'm not saying this is your problem or will solve your problem , just trying to make the other solution safer for you to work with .
Nov 01, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Icemaker not working/whirlpool ultraease
I'm sorry I don't have a solution...I am having the same problem, except the water has stopped in the ice machine. I have the same make and model refrigerator. Is it common for the water valve in the back of the frigerator to go bad? Is the valve easily replaced? Where can I buy the valve? Is there a trigger in the rear of the freezer where the icetray connects? I also took my ice tray out and it doesn't seem to fit back in correctly. I'd rather take the ice machine apart myself before I call a technician who will charge me an arm and a leg! Any further advice would be appreciated. Thank you
Jun 28, 2009 | Refrigerators
I am getting no water to go into my ice maker , eveything else works fine , just no water???
Check fill tube that goes to the icemaker in the back. It may be filled will ice or the water valve may not be sending water to the icemaker. S xS have a dual valve, one goes to the icemaker, the other to the door. This is why one may work but the other doesnt. Replace the water valve on the back of the icemaker.
May 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
171 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
