Question about Kenwood KDC-MP238 CD Player
1989 Chevy Beretta Wiring
I need a diagram to wire my KAC-606 Radio. Into my 89 beretta
Thank you
  • 15,935 Answers
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Front Speakers 4" x 6" Kick Panels Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Posted on Jan 19, 2009
Engine cranks but will not run. 89 chevy beretta 2.8
if it not firing change the coils if thats not it then you may want to check the fuse but if not firing i would check the coil because where they are located on the engine under the mainfold it gets real hot there
Apr 08, 2012 | 1989 Chevrolet Beretta
Where can i find the stock wiring diagram for a 89 chevrolet pickup radio
I assumed full size truck?
1989 Chevrolet Truck Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blu
Sep 30, 2010 | 1989 Chevrolet C1500
How do i install a serpentine belt in my 1990 chevy beretta
it should have a diagram on inside hood or inside engine compartment some where if not let me know
Dec 10, 2009 | 1989 Chevrolet Beretta
Engine turns over getting fuel but wont start. I have an 89 chevy beretta 2.8
Check for spark.If none replace coil then replace spark plugs because continuous startlng w/ no spark loads the plugs with fuel,fouling them.
Sep 15, 2009 | 1989 Chevrolet Beretta
Need to reset the time on a factory installed radio on a 1989 chevy beretta
u have turn the radio off usually the tune and seek buttons adjust the time
Mar 26, 2009 | 1989 Chevrolet Beretta
89 Chevy Beretta Fuel Lines
how do you know it needs fuel lines, are they leaking? is fuel pump good?did you do fuel pressure test? did you chk. to see if filter is pluged? just because the tank leaks won't keep it from running and that can be fix with a little apoxey and a some elbo grease.
Feb 02, 2009 | 1989 Chevrolet Beretta
I would like to know what harness & Kit i need to install radio
Metra is the only manufacture I use.
#70-1858 Wire Harness
#99-3101 (with A/C) #99-3102 (w/O A/C) Kit
Also a mini gm to standard antenna adapter is required.
#40-GM10
Jan 22, 2009 | 1989 Chevrolet Beretta
My 89 Chevy Beretta Wont Start
This is not a valid code. Please re-check and re-submit error.
Dec 29, 2008 | 1989 Chevrolet Beretta
Kenwood KDC-MP238 CD Player Logo
155 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
