Question about 7701V Responder SST Remote
Viper alarm 5704 troubleshooting
Parking lights do not flash anymore
2 Suggested Answers
logosc75
  • 625 Answers
SOURCE: i have a viper 791xv carstarter/alarm the battery
The parking light flashes are a diagnostic report to alert you to the reason the remote starter is not working:
5 flashes; brake wire is active
6 flashes; hood pin is active
7 flashes; manual transmission mode is enabled and not initialized
8 flashes; neutral safety wire has no ground or the switch is OFF.
Count the flashes and you will be able to go directly to the problem. Enjoy.
Posted on Nov 26, 2010
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
Parking and cab lights don't flash where arming or disarming. Also Lights don't say illuminated when remote start is on. Did i turn this function off?
It's possible that the parking kight wire is no longer connected or, the (alarm's) fuse for the parking is blown. The parking light fuse for the 5701 is located behind the door on the alarm module.
Jul 20, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have the viper 5701 on a bmw 540i and the alarm works so does the keyless but the remote start does not work, the park lights flash 7 times and gives an error code,what can cause this?
The flashing parking lights signal a shutdown diagnostic. There is a nuetral safety switch under the dash. It's a toggle switch that needs to be in the on position. Also, the hood pin needs to be making contact with the hood when the hood is closed.
Jun 28, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hello. My Viper 5701 suddenly doesn't start anymore. I press the button on the 2way, I get a red light by the f instead of the usual green start light. The rest of the functions (unlock, lock, alarms) work...
You should also be receiving an error message. If the parking lights flash six times, it relates to the hood shutdown wire(-) or the brake shutdown wire(+). If the parking lights flash seven times, it relates to the neutral safety shutdown. Check the toggle switch under the dash and flip it to the opposite position.
Jan 23, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a viper 791xv carstarter/alarm the battery had to be replaced on the car and the alarm works but the remote sart won't start the car on key pad it shows it 's start but then it beeps and is gone...
Nov 26, 2010 | 791XV The 791XV is a 2-way Security and...
Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Feb 25, 2009 | Vehicle Parts & Accessories
I had a viper 5701 responder LE 2 way system installed on my 2006 dodge Dakota, everything works fine but my headlights and parks lights stay on constant while in remote operation and my park lights do...
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
Dec 17, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Security car alarm
This sound like you have the system in Valet mode. You must locate the valet button usualy located inder the drivers dash or kick pannel. just turn key to on possition and hit button and then take key out. that should do it.
Nov 01, 2008 | Vehicle Parts & Accessories
7701V  Responder SST Remote Logo
81 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
