Question about Akai LCT4216 42 in. LCD Television
Backlight keeps flickering on switch on
Akai 42LCT 42Z6TM just over year old. Backlight is on blink takes several attempts to get picture on. Is this light replaceable? Where can I order Part from?
  • macnsue Feb 26, 2009
    Great, thanks for info, will comment futher when I obtain part and if it works.
  • 217 Answers
You cab buy it from ebay
Click here to view
(http://cgi.ebay.com/Akai-Back-Light-Inverter-Master-6632L-0346A-LCT42Z6TM_W0QQitemZ260321672663QQihZ016QQcategoryZ71585QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262)
Posted on Feb 21, 2009
    Brigadier General:
  • 3,614 Answers
Go HERE
The tv suddenly goes black and the power light blinks red
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 12, 2015 | LG 37-inch Led-lcd Tv - 1080p 60hz Hdtv...
Lexsor 32" widescreen LCD TV
sounds like av panel needs replacing................
cheers
Mar 26, 2011 | Televison & Video
When I turn on my Akai, I sometimes get a clear picture and then it fades out I still see what I'm watching but its faded out, the people on the tv look florescent
This could be the backlight failing (most often the images will tend to go pink). If the TV is out of warranty, you can replace the backlight(s) yourself. lcdparts.net has many backlights but you need to match the length and width to the original. Next you need to open up the back of the TV and carefully remove the old backlight(s). The backlights are on the perimeter of the TV (laptop screens started with one but most TVs have several to maintain an even lighting of the image).) The removal takes some work and paying attention to how the original is put together. The backlights are often molded into the frame of the TV and a Dremel or other rotary tool is needed to get the backlight out. Google backlight replacement for videos, pictures and descriptions of the process.
I hope this helps.
Jul 08, 2010 | Akai LCT3701AD 37 in. LCD Television
LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
Sep 22, 2009 | Philips 42PF7421D 32 in. LCD HDTV
HP Pavilion Entertainment Laptop Monitor flickers black
If the laptop is under a year old it could still be under warranty and if so I would get it repaired under warranty.
OTHERWISE
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 02, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Lines and broken digitized images on the viewing screen
Stevenson
Listen folks, these tv.s do not operate as the old tv. The tv breaks down, you simply change the board you know that has the problem only. You can solve the problem yourself if you want, but you have to know how to diagnose a problem in the new tv. First, you have a power supply board, main digital board, inverter board, and converter board. In your case you need to change the main input digital board. You can e-mail me at Stevebuy31@hotmail.com
Dec 08, 2008 | Akai PDP4225M 42 in. Plasma Television
Video keeps flickering
TRY SWITCHING VIDEO SYSTEM. PAL TO NTSC.
Jan 30, 2008 | Farenheit DVD-36 Car DVD Player
Picture flicker
You can get info at ctechnicians.com
Dec 22, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
LCD Display Flickers
if the replay is OK,the LCD is fine. Then check the CCD that is defective. We can supply LCD and as well as CCD.
Jun 20, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Akai LCT4216 42 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
