Question about HP Compaq S9500 19" CRT Monitor
Hp 9500 19"
Moniter function is automatically open eg. menu, brightness, deguess, ext.
  • 432 Answers
One of of the buttons on the monitor maybe stuck. Or you haven't pushed the right button yet to make it turn off. http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00220294/c00220294.pdf http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodClassId=-1&prodTypeId=382087&prodSeriesId=322418 http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00220294/c00220294.pdf
Posted on Jun 27, 2007
Buttons get stuck in alot...if this happened then something is going to be on the screen all the time. lightly spray buttons with wd-40 enough to get into the plastic...then wipe with paper tower, take a toothpick and wiggle each alll around or finger and press each one if u dont hear a click the button is stuck in,,,now take 2 needles on both sides of the stuck button and pull it out...the display should disapear after a while...do this again if u need to adjust it...but dont use it if all possible.mark bad over top with black magic marker...or get it fixed right at a shop...should be very cheap to fix. CrazyLarry
SOURCE:
HP W1707 screen high brightness monitor
the screen is too bright,? ( some models have ambient light sensors) so change that? if there? page 25 read that?
"If you adjust the Quick View, Brightness, Contrast, or sRGB functions in the OSD, the light sensor will automatically be disabled"
i think this is the only post in the world for that. 99.9% is DIM.
circa 2006 monitor, and no HP support
so we go to google ever heard of them?
and bingo 1st hit google, (amazing no>?)
on this monitor. push the menu button (page 30 read/?)
see OSD sure.
the press the bightness , mode using the monitors keys.
then save and exit OSD
end story, same on all monitors, for 20 years.
now the FREE book
https://www.manualslib.com/manual/71492/Hp-W1707.html?page=30#manual
now ive tought how to fish, and spoon fed at same time.
Sep 26, 2017 | HP Computers & Internet
Audio window comes on and off on its own
problem with moniter front panel MENU swithes.Replace all the swithes on the front panel.
If one swith is problem, automatically on or off will happen on its own.
This solution wil be the same even if brightness or contrast control will vary on its own!
Dec 10, 2010 | HP W19b LCD Monitor
My hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.
<div style="FONT-SIZE: 14px; PADDING-TOP: 10px" itxtvisited="1"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblProblem" itxtvisited="1">my hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.</span> </div><!-- answer --><!-- from fixya rte -->
May 12, 2010 | HP S7540 17" CRT Monitor
Moniter's menu option gets automatically selected whenever i open my moniter screen
arpanpallar, If you are certain that pc not causing problem, then hp internal "switch-mode-power-supply" could be the problem. Noisey DC source will cause very strange things to occur on screen!! You or technician will need to look for common visual signs of bad capacitors on the circuit board. Do some reading in my and other CCFL back-lit lcd monitor tech's fixya profiles. 12fixlouie
Mar 12, 2010 | HP Computers & Internet
How do I use the function keys eg volume and brightness on my compaq 6720
go to hp web site look for the manual for the model you have and you will find out how to use your hot keys.
Sep 10, 2009 | HP Compaq 6720s Notebook
Moniter lost full brightness
Download Powerstrip here http://entechtaiwan.com/util/ps.shtm (on the left on top "PowerStrip - international). Install the program, and from there you can change the brightness, contrast etc.
Jul 20, 2009 | HP F207260918 Monitor
What is "OPC"? It comes up and goes away.
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Open Questions:
See all HP Compaq S9500 19" CRT Monitor Questions
HP Compaq S9500 19" CRT Monitor Logo
184 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
