Question about Frigidaire Washing Machine V-Belt Replacement Washer Drive Belt 134511
Need manual for frigidaire gallery washer fws446ghs1
  • 1028 Answers
SOURCE: I need to replace the
remove fill hoses remove a zillions screws from back remove belt from pulleys remove 2-4 bolts from motor and slide toward front unplug wire harness
Posted on Jun 30, 2008
venexcsd
  • 1185 Answers
SOURCE: i have a frigidaire gallery front load washer need help
Run the machine on a cycle with no load in it (no soap powder either)
If it makes the same noise when there are no clothes in it then the suspension legs have given way or the counterweight has come loose.
You will need someone who knows what they are doing to repair it
Posted on May 23, 2009
  • 512 Answers
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Posted on Sep 03, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
  • 4088 Answers
SOURCE: Need directions to remove broken drum vane in a
Open the top of the machine (look behind the top for several screws to remove) and slide it back to release from the cabinet. This should give you access to the screws that hold the vane in place. Hope this helps!
Posted on Jun 28, 2010
Do you know the bearings & seal # for the Frigidaire Gallery model # FWT449GF0
Hey friend, thanks for your post!
I have attached a copy of the parts manual for your Frigidaire washer within the manual you will find all the parts available for your appliance. I hope this is helpful. -Matt
Frigidaire Manual Search Results
Sep 01, 2014 | Frigidaire Washing Machines
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
Cant open frigidaire gallery washing machine door
Hi.... if you can't open your door you have something in your drain pump or you need a new pump ... If your washer can't drain the water out yoru washer will lock you out ... till the water is gone
Mar 24, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
No Manual
Please go into fixya.com and give me a rating,Solution solved ,etc..
Neil
Jul 22, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Washing Machine V-Belt Replacement Washer Drive Belt 134511 Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
