Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Profile smooth cooktop F113 error code
Burner sensor light stays on stating the burner is warm (but it's not), and when we try to turn on that burner, we get a F113 flashing error code and cannot use the burner. We have flipped the circuit breaker (as recommended), but this did not reset the cooktop.
  • 1 more comment
  • Anonymous Mar 05, 2009
    Same problem!
    The light stays on indicating that the surface is hot, but we verified that is not true. Turn on the cooktop, and the Error F113 flashes. Cannot use the cooktop
    What can be done to fix?
  • cehrlic Mar 22, 2009
    Same as gatorgang. Can't use LF Range due to F113. Light sensor stays on even when I have not used it.
  • Anonymous Apr 03, 2009
    I read that it is from a burner going out. I had one burn out, now I get error f114 and nothing works
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check service manual and see what it say about err f113 or call service
Posted on Apr 02, 2009
Hot surface light stays on on GE Profile Cooktop model JP989 and On does not light for left burners. This is only happening on left burners. Left front burner goes to high with any setting on the switch...
You could have a shorted burner, if it is not then you may have gotten a bad part.
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | GE 30 in. Profile JP989 Electric Cooktop
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
I get an error message F113 for one burner
This indicates failure (open circuit) of the left front temp sensor. You can search for my solution for replacing a element on a JP939 and JP969. Will likely require replacement of the element (~$160).
Mar 24, 2011 | GE 30 in. Profile JP939 Electric Cooktop
F113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Front left burner indicator light stays on and i get an F113 code when I try to use this burner
The "F113" error code means "Open temperature sensor".
The problem could be a bad sensor/wiring/ control board.
This stove is very complicated and you may be better to call for service.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 08, 2009 | GE Profile 30" Free-Standing 5 Burner Self...
Looking for Cause of Fault Code on GE Range top JP939
Have SAME EXACT issue - F113 on Left burner. Indicator says HOT and not even on. Called a service company (NOT GE SERVICE). They said the Element Radiant is no good and must be replaced. Part is quoted as $323.98 !!! What a rip off from GE !
Jul 02, 2008 | Cooktops
Refrigerators Logo
1,071 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
