Question about Magtek Office Equipment & Supplies
I can't get the Magtek Mini MICR USB to work with a PS to USB adapter
I'm trying to hook up a Magtek MICR MINI USB check scanner through Parallels with a PS2 to USB adapter (StarTech.com) But it won't connect. I need it to show in the COM port, but nothing shows. I had an older model Magtek MICR WEDGE MINI that worked great. This one is confusing because it comes with a PS2 connection even though it is a USB model.Go figure. I tried a different PS2- to USB Y cable and it didn't work either.
pastorm
  • 98 Answers
SOURCE: problem connecting and printing my lx-300 matrix printer
You need to get a paralell to USB cable, like the one on the following link: http://catalog.belkin.com/IWCatProductPage.process?Product_Id=20651
Posted on Sep 08, 2007
  • 8 Answers
SOURCE: Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Posted on Sep 23, 2007
SOURCE: Lexmark P315 connecting to Fujitsu Finepix S5100 Digital Camera
I belive Lexmark P315 only accept 256 mb cards at the largest
Posted on Jan 02, 2008
  • 8 Answers
SOURCE: Dell 3000cn Network Connection not working
First of, the ethernet must be 'on'. If dhcp available, set it to auto (or dhcp.. anyways..) and let it reboot, just in case :)
if not, try setting the IP-setting yourself. They should be somewhat similar to the settings on your local computer(s).
To add the printer to your computer, select 'Local' printer and specify 'tcp/ip' as which port its connected to. In the new window the ip to the printer should be entered. :) (at least for XP this is..)
Hope this gave you the correct solution..
Posted on Mar 18, 2008
  • 113 Answers
SOURCE: How do I connect my Motorola w375 to PC
try downloading the motorola usb drivers and installing them.
i would try that first.
you could also get motrola phone tools software which comes with the drivers and can transfer the photos from your phone
Posted on Apr 13, 2008
Ordered HDMI BASIC to HDMI MINI You sent USB Basic to micr
Contact your supplier. We don't sell on this site.
Feb 21, 2015 | Computers & Internet
How do i hook the desktop up to wireless internet
I bought a Trendnet USB mini wireless adapter and it works good, I little trying at first to set up but it works good. Try Compusa or maybe BBuy.
Mar 10, 2012 | Dell Inspiron 531s Desktop Computer
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Need drivers for magtek 21040102 to run it on windows 7
The best tool for keeping your drivers up to date is: driverupdate us Its, easy to navigate (user friendly) and easy to install. take a look
Mar 07, 2011 | MagLite MagTek Mini Swipe Magnetic Strip...
Scanner ouput is missing data from the scanned barcode
yes i have the same problem, when i am using usb keyboard..
but if u use standard ps2 101-102 keyboard it is working properly
Aug 13, 2009 | Microsoft Metrologic MS9520 Voyager...
USB MINI WIRELESS ADAPTER PASSKEY
right Click on the wireless network connection
go to properties.
Under the wireless folder.
go to advanced.
Click on computer to computer adhoc networks only.
It should work then.
I am assuming you have wifi on your desktop.
Best case go out and buy a wireless router. It will be more secure.
Jun 30, 2009 | Adapters.com USB Wireless Mini LAN Adapter...
Can't get the thing to work
Hi Madm
plz donate if u can on paypal madridtelecom@gmail.com.
check the following:
  • the USB cord.
  • The Reader is faulty.
  • Or the USb Slot On the computer is not working .
  • Check drivers for ur Reader so windows detect ur driver.
PS: for every solutions check the removable disk on my compueter section.
plz rate this post.
Feb 09, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Connect to usb on laptop
The Easy affordable solution:
www.sewelldirect.com or (801)356-3823
* USB to Parallel Adapter, part # SW-1302 ($14.95) + * Centronics to Mini Centronics, Part # SW-2104 ($12.95).
I ordered before 2pm EST and received two days later.
Plug usb into computer, wait, then plug in printer. Voila! Instantly worked!!
PS: Found this site after www.monoprice.com Product ID: 2277 (parallel to USB) and ID 257 (male to mini) - $15
Oct 24, 2007 | HP LaserJet 1100 Printer
51 people viewed this question
Top Magtek Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Magtek Office Equipment and Supply Expert? Answer questions, earn points and help others
