Question about Canon PowerShot A70 Digital Camera
Pitctures are gray & have horizonal lines
Beginning today all of my pictures are faded gray & have horizonal lines across them. This is both on the camera screen and when transfered to my computer. I've changed batteries, re-formatted the compact flash card, tried resetting to default setting. Does this mean my camera has died? Could the card be bad? Any help will be greatly appreciated. Thanks in advance for any help.
Canon has a recall for this. I just sent mine in. They fixed it for free (including shipping) and I had it back in a week! It was great. Here's info on the recall. http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Posted on Jun 27, 2007
The ccd image processor is most likely bad, or the horizontal sync lost it. eather way i would change the main board out inside..its probably layered ..u can look for a horizontal adjustment or any on the board...tweek it one way the other way and back closer to where u found it. then find a tech if that dont work or sell on ebay i bay broken cameras but i wont buy yours. I like fujifilm and the old minoltas and pentax.
SOURCE:
TAC-125 telefunken does not switch of and the screen is sowing green and gray lines across the screen
If the camcorder won't switch off, just open the battery compartment and remove the batteries. Let the camcorder stand for a couple of hours (or preferably overnight), then replace the batteries and try again.
FWIW, many camcorders will only let you transfer files to a PC if the camcorder is mains-powered, so that the transfer will not be interrupted by the battery failing part way through.
May 23, 2016 | Cameras
When I take a picture the screen shows the picture but has black and white horizonal lines.When I transfer to computer lines remain in picture. I have a DSCS650
I have the same issue with my DSC s650 , I showed it to a Sony Service center they said its a CCD issue might need to replace that. The cost for replacement in India (Pune) was 2250.So I thought of buying a new one at say 4K INR
Jun 12, 2011 | Sony Cyber-shot DSC-S650 Digital Camera
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
Lines show across my camera when I take a picture
Try the steps below.
Remove the Memory card
try to take picture w/out the card
if there are lines, transfer picture on the computer.
If lines exist when pics are transferred to the computer, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EasyShare Z612 Digital Camera
HORIZONAL LINES FLASHING ACROSS SCREEN
lens is damage at this time but it still work normally... contact your technical to fix it...
Jun 17, 2009 | Canon PowerShot S230 / IXUS 179 Digital...
Mustek Scan Express A3 USB
Got same problem. Beginning to suspect the traveling lamp or associated electronics. Looking out for parts suppliers for elimination trials. Strange, once in a far while it works. Updated drivers again this very day.Suggest you try a good power adapter, and if you are technical, search for loose connections. Will keep you posted if I solve mine, being an electrical engineer, NOT electronics.
Pax
Jan 15, 2009 | Office Equipment & Supplies
Gray faded look on top to picture
It can be the anty polarizing plastic screen that protects the display.
Often it causes grey or reddish shadows, in that case must be replaced.
Sep 15, 2008 | Televison & Video
Toshiba 32AF42 Poor picture quality
TRY ADJUSTING THE SCREEN CONTROL ADJUSTMENT AT THE BOTTOM OF THE FLYBACK TRANSFORMER.THIS SHOULD REMOVE THE RETRACE LINES AND ANJUST THE HASY LOOK TO THE PICTURE IF NOT YOU HAVE A BAD CAP IN THE SCREEN CIRCUIT .LOOK FOR A 10MFD/250V CAP IF FEEDS THE NECK BOARD ATTACHED TO THE PICTURE TUBE 200V DC.
Jun 22, 2007 | Toshiba 32AF42 32" TV
Faded screen with lines across screen
hi Jenredd, i think there is something wrong with ccd, if so it is serious... . I experienced some disturbed picture on lcd or whole black lcd due to ccd problem. As u said you pictures are fadded it means may be ccd is damaged. If so you have to replace the ccd at any authorised repairer for fuji. as you mentioned other problem there is nothing common between both. for that i suppose there is some problem in either usb socket or cord , so first check the cord, if it is ok then we can doubt on usb socket. But in both the way you have to go to Fuji . good luck
Aug 01, 2006 | Fuji FinePix A345 Digital Camera
Canon PowerShot A70 Digital Camera Logo
48 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
