Question about Dryers
I have a dawnsun ceiling fan model efu12lr3oos you comented on this about the light blinking on and off. my problem is everything is working from the remote except the light will not shut off when you hit the button
SOURCE: Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Posted on Sep 05, 2007
jmgldsmth
  • 2005 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
  • 3640 Answers
SOURCE: I have 2 of the same Hunter Douglass ceiling fans
if problems with blinking lights, remove watt governor on inside of fan for the lights.its a black box,white to white wire and black to red wire. and wire it direct without watt governor or black box. this should fix the problem. the part # 98480-02 for watt governor. they installed watt governors on ceiling fans to reduce light wattage.
Posted on Jun 01, 2011
How do i contact Dawnsun to order a new ceiling fan remote?
Dog ate my phone (truly ) .Go on line for manufacturer parts.
Jan 16, 2015 | Dryers
I have a ceiling fan with a remote and the remote stopped working. The light blinks on the remote when I press the buttons, but the fan doesn't work. The model number of the
The light on the remote is just a battery indicator light. I would try changing the dip switches in the receiver & transmitter first. If that doesn't work, you probably need a new receiver. Good luck since this is a cheap store brand.
Oct 01, 2013 | Hampton Bay 24002 Ceiling Fan
Our ceiling fan lights are blinking. There are 3 bulbs that have always worked fine until yesterday when they all 3 started blinking in unison.
sounds like you have a lose wire, pull the light housing and check the connections. If all is good, drop the unit, and check the connections in the ceiling. You have a short in the power , and is showing you when the fan is spinning. I would not use light or fan till fixed.
Mar 13, 2011 | Hunter (25417) Ceiling Fan
My Hunter ceiling fan model 21332 lights are blinking but I did not find the watt governor on the light assembly. How can I fixed the blinking light problem
If the lights are blinking when the the fan is on, the blinking is probably caused by vibration of the fan running. Which may indicate a loose wiring connection within the light kit housing. Or the light kit is not wired properly to the fan. In any event, the only way to check this is start taking the light kit apart were it attaches to the fan and search for loose connections (wire nuts). If none are found, continue to the electrical connections where the fan is mounted to the ceiling. If the light kit is controlled by a dimmer switch on the wall, the dimmer switch may also be the culprit. Be sure to turn the circuit breaker off to the line that feeds the fan before attempting any repairs.
Feb 07, 2011 | Heating & Cooling
The light portion of my hunter ceiling fan is blinking. At first it started blinking, then it didn't work at all, now it is blinking again. What is wrong?
the blinking is caused by the watt governor to lights( its a small black box with slots in it ). just remove this box and wire direct. this should fix problem.
Dec 10, 2010 | Hunter (25417) Ceiling Fan
I have 2 of the same Hunter Douglass ceiling fans with double light kits in my living room. Yesterday one of them started blinking the lights constantly when I tried to turn on just the lower bowl light....
Sep 19, 2010 | Hunter Fan/Light Wall Mount Control 27186
Model 740 154 Hampton bay Mediterranean ceiling fan
Make sure the switches in the remote and the receiver board inside the fan canopy are set to 3
Sep 06, 2009 | Hampton Bay 52 In. 5-Blade Ceiling Fan,...
Dryers Logo
91 people viewed this question
Top Dryers Experts
