Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Netgear wpn824 wont connect to setup page
Hi guys my router cant seem to pass out an ip address to my pcs, i reseted the router with a paper clip it reset's fine but when it comes back up the test light (check mark) keeps flashing. n then the pc would just say accquiring network address then to limited or no connectivity. how do i slow this problem please help
  • 4 more comments
  • piyush615 Jan 19, 2009
    i cant get to that site because the the router is not assigning any ip to the pc. i need some kind of connection inorder for me to get 2 those sites.
    ya i put the IP and tried to go 2 192.168.1.1 but no luck.
    problem solved ....bought a new router ...when check mark light keeps on flashing the router is a defect per netgear so i got an exchange on it..thanks guys
  • Carl Navarro
    Carl Navarro May 11, 2010
    Strange, Netgears are pretty easy to set up. Try holding the reset button in for at least 20 seconds, and see if you can ping 192.168.1.1. You did plug a PC into the router and turn off the wireless?
    Even in default the Netgear is supposed to give out DHCP addresses, so you can do an ipconfig and see whether that happened after you set the network card to Obtain Automatically.
  • Carl Navarro
    The setup instructions for the router tell you to plug your pc into one of the 4 LAN ports, do not plug anything into the WAN port, and set your IP address in the network card to any address like 192.168.1.2-254, the mask to 255.255.255.0 and you don't need a gateway. Then open up a browser and go to 192.168.1.1, and login using admin and password.
    Did you miss any of the above steps?
  • Carl Navarro
    Resetting the router gives you a chance to set it up. Go to www.routerlogin.com or 192.168.1.1 after it says limited or no connectivity and set it up with the wizard.
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 08, 2009
I tried connecting to my wireless and cant remember the password. how do I reset it
You could try to go to the default IP address which is usually somewhere on the back on underneath the router.if it's netgear it usually goes to 192.168.0.1 then you need to log in the default user pass which is admin admin but sometimes with capital A.you can google most router ip addresses and user pass to get to the setup page of the router.if you can't there is also a reset button somewhere on the router.you will need a safety pin or needle to hold it in for at least three seconds?the router will reset but you may need to reconfigure the settings to your ISP.
Jan 11, 2015 | Computers & Internet
I have a Netgear WPN824v3. It seems to be functioning normally except I can't APPLY any changes. I get a "wait a moment" and repeated looking-up of routerlogin.net, but no response. Viewing the router's...
It seems that you need to reconfiguer router
please follow steps to reconfigure router
RESET THE ROUTER :
1. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing Power cycle the unit.
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5.Login to the router (Username = admin Password = Password)
6. Click on lan ip setup under advance.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. click Apply.
17. Open up another browser window and try to access internet.
hope it will resolved your issue
Thanks for using Fixya
Jun 09, 2010 | NetGear RangeMax WPN824 Router
I have att and speedstream modem and netgear router and get a connection but cant get on internet
HI, please perform the below steps to reset and reconfigure the router:
RESET THE ROUTER :
1. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button. 2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing. 3. After few seconds when the test light stops flashing Power cycle the unit.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer. 2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.). 3. Put http://www.routerlogin.com/basicsetting.htm in address bar. 4. On the basic setting page scroll to the bottom and click on Apply. 5.Login to the router (Username = admin Password = password) 6. Click on lan ip setup under advance. 7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise. 8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer. 9. Power off the dsl modem and the router after making the connections. 10. Power on the dsl modem and wait till the dsl light comes on, then power on the router. 11. Open the browser (Internet Explorer or Mozilla Firefox). 12. Access the router (http://192.168.10.1). 13. Login to the router (Username = admin Password = password). 14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window. 15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the username & password of your dsl account in case of pppoe detection) and then click next. 16. click Apply.
Check if you can go online with this connection. Once online on the computer through the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Mar 13, 2010 | NetGear RangeMax WPN824 Router
How to do a complete reset of netgear wpn824 v2 have pressed reset button and nothing have used holding reset button with unit on for 20 sec then off 20 sec then on again for 20 sec with out releasing...
Well it seems that you have uploaded the firmware on the router using wireless connection. The firmware on the router has corrupted and now does not seem to be recoverable.
Dude if it is under warranty then get it replaced. To log a complaint with NETGEAR go to this site:
http://my.netgear.com
Jul 05, 2009 | NetGear DG834G Router
Can't retrieve WEP code
If the default username and password is not working, try your commonly use username and password coz there's a possibility that you already change it but if it still not working better reset the router.
To reset it juts press and hold teh reset button of the router using a pen then after that you need to reconfigure it back and you should be able to access the setup page of it using "admin" as the username and password.
Hope it helps..
Jun 13, 2008 | NetGear RangeMax WPN824 Wireless Router...
No connection trough router
Hi Thumbsucker,
Oftentimes with Netgear routers, before an Internet connection can be established, you'll need to run the Wizard setup routine on the router itself. Many other manufacturers don't require this, but if you're connecting to a PPPoE connection (such as DSL) then the Netgear requires said basic setup.
On the bottom of the router itself you'll see some information. It'll tell you the default IP address (such as 192.168.0.1) and a basic username and password (the default for most Netgear routers is admin for the username and password for the password). Plug your computer into one of the four switch ports on the router (not the uplink/Internet port) and type in the IP address of the router (again, such as 192.168.0.1) into your Web Browser (such as Internet Explorer). If it asks for a username/password then punch in the info given on the bottom of the router. At that point you should be able to answer the basic questions to get you online.
There is a chance that your modem and your router have the same IP address; in that case, you'll need to manually change the IP address on the router.
If by chance you can't get into the router via the information provided on the bottom of the device, take a paper clip and, with the router powered up, hold in the reset button for 30 full seconds. This will reset the device to its default factory settings.
Ben
Mar 01, 2008 | NetGear WGR614 Wireless Router
Can't connect a PC to internet via rangemax
Sounds like the network card on the 3rd computer might be set to a manual ip address. Is the rangemax router the dhcp server? if so is the network card on the 3rd computer set to obtain an ip address automatically?
can you tell me the ip address of the rangemax router?
whats the ip address of the 3rd pc?
Thanks,
Brad
Feb 21, 2008 | NetGear RangeMax WPN824 Wireless Router...
Reset
You can reset your Netgear router/wireless wpn824 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless wpn824 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear wpn824 router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the wpn824 router has been reset.
Feel free to get instant online Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Dec 15, 2007 | NetGear RangeMax WPN824 Router
Still can't get access to the Router
By your post/description that the wizard starts @ 192.168.1.1 and it can identify your Internet Connection indicates that chances are, there is nothing wrong with your Netgear RangeMax WPN824 Router. Clicking on the Next tab does not make your browser go to the subsequent page is perhaps a problem with your browser and not with the router. You can try tweaking your browser:
• In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
• In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
• In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Alternately if this doesn’t work, try manually configuring your PC’s Network settings:
Click on Start, Control Panel, Network Connection, right click on the networking icon (that is used to connect to the router; WiFi or LAN). Click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right). In the General tab:
• tick "Use the following IP address"
• Enter values as shown below -
IP address: 192.168.1.201 (201 can be any number from 2-254 that is not in used by any other PC in your Network)
Subnet mask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS servers: as provided by your ISP
click on OK, OK, Close.
Additionally, you can try right clicking on the Networking icon (bottom right side) in your Systems Tray and click on Repair.
Worst case is you try and do a hard reset of your Netgear RangeMax WPN824 Router by pressing the small Reset button at the back or bottom for a couple of seconds or till the LEDs flashes. Pls be reminded that a full/hard reset will revert all router’s configuration to factory default.
Should you still need the setup files, they are available at the NetGear site here (depending on the version number). Further manuals, instructions and other documents for this router is available here.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 14, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
877 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
