Sanaui switching problem ic used lc 863332a 5R58 system
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Jun 02, 2015
My Sharp LC-60TQ15U is behaving weird for a week, it switch on via remote and then stop responding to remote. Suddenly menu comes and selects picture settings on its own.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 14, 2017 | Sharp Televison & Video
Sharp aquos lc-32cfe6131 while retuned the channels they are not saved after switched tv off
Feb 18, 2017 | Sharp Televison & Video
Tv channel changes on its own
Check and replace it main system control memory IC & all micro-switches at its front panel control board. Contact any service technician.
Gopakumar Gopalan Google
Feb 22, 2014 | Sharp LC-22L50M-BK 22" Multi-System LCD...
Sharp LC-70LE650U not powering up flashing icon 2 slow 3 quick which circuit at fault?
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 22, 2013 | Televison & Video
My tv wont turn on by power button or remote. white light keep blinking.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
About sanaui tv using system ic LC863332A 5R58
What do you want to know? Provide more details please. Check this and see whether it help you.
Jan 04, 2013 | Televison & Video
Pin code for sharp aquos television model number Lc 32 gdbe
Phone Sharp customer care, they will guide you trough the process.
Nov 08, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I need the code 2 program my remote to my tv! I have a GE remote and a Sanaui TV!
the code is 0463
Kindly rate my help++++Thanks for using FIXYA
Oct 16, 2009 | GE Televison & Video
My TV wont switch on
check horizontal transistor for short circuit,if ok try disolder audio ic or vertical ic and see which one is fault try replacement. frank massawe
Dec 28, 2008 | Sharp LC-32P50E 32 in. LCD Television
Sanaui
This is a device which gives the illusion of more spacious sound by adding reverberation (echo) to the audio signal. This particular unit uses a mechanical analog delay mechanism employing a steel spring! Analog spring reverb units enjoyed some popularity in the late 60's and early 70's, with the Sansui and Pioneer units being the most common..
Feb 12, 2008 | Audio Players & Recorders
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
