Question about Microwave Ovens
NN-A574SBBTQ panasonic oven door jam
Door jammed
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Oct 22, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic NN-T687 (The Genius) door
You will need to remove the oven from the frame, then remove the outer cover from the door.
Once the outer cover's off, you'll be able to see that door opening button presses against the door opening lever, which presses up on the door key/hook to open the door.
Usually the problem is a broken door opening lever.
You can order that part directly from Panasonic here.
Once it's fixed, if you want to download the owner's manual, it's here.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: broken door catch, possible spring,
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
EwingElect
  • 276 Answers
SOURCE: our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Posted on Mar 27, 2009
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
Panasonic inverter microwave model NN-A574SBBTQ . The turntable has stopped working. Any ideas please.
If everything else is running, it means the turntable motor has become defective and will need to be replaced, this is a common problem with many brands.
May 15, 2011 | Microwave Ovens
Jan 19, 2010 | Panasonic Microwave Ovens
Panasonic over the range "genius" model door won't open. Is there lock on it?
No, there is no lock. The latch is jammed. This is a toughie. Breaking the door or latch seems wasteful. Can you return it? How did it get "stuck"? m
Nov 09, 2009 | Panasonic NN-SN657SMicrowave Oven
Our microwave oven Panasonic NN-S252WF stops after
Mar 27, 2009 | Panasonic NN-S252WF Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
