Question about Symbol LS2208 Handheld
I can't get 123scan to find Symbol ls2208 barcode scanner, printing and scanning the barcode as suggested doesn't work.
  • 74 Answers
SOURCE: hi my name is christian
Hi Christian, if your scanner was manufactured before February 2010 it may not be able to communicate directly with 123Scan2 so you wont be able to upgrade firmware with the program, but you will still be able to use it to create configuration sheets. These are the only two uses for 123Scan2.
To create a configuration sheet without "finding" the scanner click Create New Configuration then choose My scanner is NOT connected. Select the LS2208 and click on the blue firmware button to get into the configuration. When you have completed your configuration click the Print bar codes selection at the top of the window and when the file comes up be sure to click on the Bar code formatting menu and change the Bar code type to 1D One setting per barcode if it is not already there. Older scanners will not work with concatenated 1D barcodes where 123Scan2 puts more than one setting into a barcode.
Posted on Feb 14, 2011
SOURCE: LS2208
Symbol has confirmed that there was a batch of scanners sent out with defective lasers. Call them at 800-653-5350 for a replacement. Have the scanner handy to give them the serial number. They were very helpful.
Posted on Jan 20, 2009
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
thesuperdude
  • 97 Answers
SOURCE: is it possible to send two suffix in symbol ls2208
Yes it is possible.
You will need to create the following adf rule which you can do using 123scan.
the barcodes generated will be the following:
Begin new rule.
Send all that remains
Send Extended key <Enter>
Send extended key <Enter>
Save Rule.
If you can't generate them, I can send you a pdf document with them already created.
Posted on Apr 02, 2009
  • 41 Answers
SOURCE: hi, i am trying to configure my barcode scanner
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Posted on Feb 26, 2010
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
After scanning it is automatically not going to the next line
Symbol barcode scanners by default do not add a return after a scan. You need to program the scanner to add a suffix.
Download the manual from Motorola/Symbol here
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf&sliceId=&dialogID=219596399&stateId=1%200%20219598121
-Print Pages 224 and 225
-Scan the Barcode "Scan Options"
-Scan the Barcode " "
-Scan the Barcode "Enter"
Scan a barcode
Feb 26, 2011 | Symbol LS2208 Handheld
Ls2208 Barcode Scanner program for .NET
here is the Barcode Scanner Program right now, it seems like being able to scan barcode with Symbol Ls2208 handheld device.
if it is not workiing, go to this barcode website to find more compatible software for Ls2208, i am sure you will find the proper one.
NET Barcode Reader Barcode Reader ASP NET Barcode Reader VB NET Barcode... Barcode Components NET Barcode Generator Reader Java Barcode Generator...
Jul 28, 2010 | Symbol LS2208 Handheld
Reversing first 2 digits of barcode
Attached are the programming barcodes for the LS2208 solve this problem. Print the attached file and scan the barcodes in order 1-10. This will only work on a LS2208. If you scan the Set Defaults barcode it will erase this programming rule.
there is a document you will need to scan to do this, if you want to send me an e-mail i will send you the document
kganoe@datexcorp.com
Mar 13, 2010 | Symbol LS2208 Handheld
Symbol LS2208 I need to scan in a barcode then add a tab then input 1
From the LS2208 Product Reference Guide you should print and scan the following barcodes:
Begin New Rule Adobe page 232 of 342
Send all data that remains Adobe page 246 of 342
Send tab key Adobe page 286 of 342
Send 1 Adobe page 270 of 342
Save Rule Adobe page 232 of 342
That should do it. If you find the scanner sends the 1 too quickly after the tab key you may want to scan Send Pause in between the Send tab key and Send 1 statements.
Mar 09, 2010 | Symbol LS2208 Handheld
I use usb base ls2208 my problem is every time
Hi, to make the scanner automatically hit enter print and scan the barcodes Scan Options, Data Suffix, and Enter from Adobe pages 222 and 223 of 342 of the LS2208 Product Reference Guide.
Jan 06, 2010 | Symbol LS2208 Handheld
LS2208 Can get it to work no driver
If your scanner shipped with a keyboard wedge cable and you are using a PS/2 to USB adapter all you should have to do is scan the IBM AT Notebook barcode on Adobe page 56 of 342 of the LS2208 Product Reference Guide. I suggest saving a copy of the document to your host then printing just that page. Scan the barcode then try scanning your barcode. If the computer still does not see your barcode try rebooting. If this still does not resolve your issue you may want to purchase a USB cable. The part number is CBA-U01-S07ZAR.
If you have the CBA-U01-S07ZAR and the scanner is not sending data then you should scan the HID Keyboard Emulation barcode from the QRG that came with the device or Adobe page 109 of 342 of the guide referenced above. I hope this helps.
Oct 20, 2009 | Symbol LS2208 Handheld
LS2208AP
The scanner must be set to the IBM PC/AT host type. Unfortunately, these scanners are not plug and play. They do not detect the keyboard host on power up so the host type barcode must be scanned the first time it is setup. It should remember that host type until you set defaults. The IBM PC/AT host type barcode is on Adobe page 56 of 342 of the LS2208 Product Reference Guide. Print and scan this barcode. The scanner should start working immediately.
Oct 31, 2008 | Symbol LS2208-7AZK0100S Handheld
Scanner Symbol Ls2208 keyboard not work
The scanner does not detect the keyboard host on power up and is locking up your keyboard. The IBM PC/AT host type barcode must be scanned the first time it is setup. The barcode is on Adobe page 56 of 342 of the LS2208 Product Reference Guide. The scanner should start working immediately after the host type barcode is scanned.
Jan 30, 2007 | Symbol LS2208-7AZK0100S Handheld
Symbol LS2208 Handheld Logo
2,400 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
