Question about LaCie Big Disk External USB 2.0 1TB Hard Drive
Lacie external HD blue light blinks continuously, won't mount
Have 640GB LaCie external hard drive. When I connect the drive to my Mac and turn the drive on, the blue power light just blinks continuously. It fails to mount on the computer so I cannot access the data on the drive.
Is this potentially just a problem with the interface of the external enclosure, meaning I could extract the drive in the enclosure by disassembling it? Or do you think the drive has actual had a failure, and I have lost the data?
Thank you,
Malachi
    Top Expert:
  • LaCie Master
  • 14,161 Answers
Posted on May 24, 2016
  • 158 Answers
SOURCE: enclosure replacement Lacie Porche 250
Rock 5.25" USB 2.0 & Firewire Enclosure Like the HD506, the Rock 5.25" is also the bigger "brother" of the Rock 3.5" enclosure we sell but this version has the benefit of support your CD and DVD reader/writers and its got a built in fan as well. try this model of enclosure it depends on hdd connection you could go for a diffirent model hope this has helped you
Posted on Aug 14, 2007
SOURCE: lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Posted on Jan 08, 2008
Beni S-P
  • 1006 Answers
SOURCE: lacie hard drive
The problem is just external...Hdd is fine..Just buy new external couse there is no way to repair it
Posted on Jan 27, 2008
IB4G2008
  • 3587 Answers
SOURCE: Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Posted on Mar 09, 2008
SOURCE: Lacie drive won't mount
Ive solved the Whole Lacie wont mount problem.... Thanks to Lacie support center, Best Buy, The internet and several Tech shops I took my crashed lacie d2 quadra 500 GB hard drive to for help when it crashed. They didn;t help and none of the stuff I bought helped either. Here is the solution: Take any of your crashed lacie Hard drives (That are clicking and making a noise to a Windows OS) FOOTNOTE: NO MATTER WHAT ANYONE SAYS, YOUR LACIE HAS NOT CRASHED AND DOES NOT NEED DATA RECOVERY$$$$$$$$ Take it to a Windows (XP worked on mine) install your lacie one button disk, after its installed properly, Run the lacie one button recovery by clicking the blinking and clicking switch on the hard drive the program will come up and show the Lacie Hard drive. Go to windows control panel and run add hardware program and search once. (if it hasnt mounted it will not find it) just let the search go through once and after it says can-not find hardware leave it open. Go to My Computer and open it, keep the window open that shows all of your drives. Wait about 4-8 hours depending on what you have going on (go to the movies or go to sleep) and come back and your lacie drive will be mounted. (THIS IS NOT THE LAST STEP- DONT GET HAPPY YET) This is whats going to burn your attitude to a new level. The Lacie Hard drive is SUPER un responsive. I advise opening just the main window and taking a look at all the folders and files you have on them. ( i solved mine by simply erasing the Video files. Final cut pro cache folders etc.) if you use your hard drive for things like editing video and audio then more than likely your drive is slightly corrupted (don't get angry) this does not mean its trashed, it means that there is a problem with file structure and a single or several files confused the hard drive. Once again your lacie is not trash. I used mine for video editing in Final cut Pro, and Audio in Pro Tools, among other things like saving photos and software, etc... Just take the time to simply delete what you know you dont need.. or even better, format the entire drive and it will be like new. Another step you can take in mounting your Lacie is to download Mac Drive 7, install it on a PC- not MAC, this process WILL NOT work on a MAC (none of these steps will work on a mac- Trust me, not matter what these nerds say, dont believe that it will- its going to cost you.) Install the Mac Drive 7 on a pc, run the Error Check and repair function and it will take about an hour depending on what you have on your drive and how many errors are found. and It will fix the drive. As stated previously - these steps will ONLY MOUNT YOUR DRIVE. Access to the files and folders on your drive will be very unresponsive. Basically if you plan on copying a movie to your desktop forget about it. 30Mb would take about 2 hours. 6Kb took close to 4 mins to copy from the lacie. You wont be able to back it up so forget about that too. Just follow the begining steps and find out what has done this to your Lacie (you know what it is!). As stated previously- I used my LACIE D2 qudra 500 GB Hard drive (that is only 6 months used) for average things like downloading, uploading, saving, etc... the same things you do, Plus I ran Final Cut Pro, Pro Tools, Logic Pro, and a S**T load of other programs on this drive and what confused or "Corrupted" my lacie and made it BLINK, CLICK, and make STRANGE
Posted on Mar 19, 2008
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
My Mac suddenly cannot find my Lacie external storage device. I have turned off, unplugged, restarted... etc. and it is still not finding it. The Lacie seems to be on, at least the blue light is...
A continuous flashing light on a Lacie drive is a notification of a problem. I do wonder if the light is flashing the same if the drive is plugged in to the Mac or unplugged.
Lacie external drives tend to have power-supplies which become weak/bad. Most users replace the supply and it will work again for awhile until the supply dies again. Try bringing the drive to a retail dealer with Lacie drives -ask them if you can just test your drive with another power-supply (if you do not have another). You can also try calling Lacie, it's always slightly possible they will be aware of this problem.
Alternately, IF the light is only flashing when the drive is plugged-in to the computer, try using a different USB or Firewire cable.
Aug 31, 2009 | LaCie Computers & Internet
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
rmatheson@wowway.com
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Lacie hard drive
Jan 12, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie d2 HD Quadra 250gb
Lacie D2 drives in my experience are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a blue light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure.
Hope this helps.
Dec 01, 2007 | LaCie (300770) 250 GB Hard Drive
Lacie d2 external drive
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
Open Questions:
LaCie Big Disk External USB 2.0 1TB Hard Drive Logo
814 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
