Question about Maytag Performa PAV2200
Water on floor after running load
There has been a puddle of water on floor on left front side of Maytag Performa washing machine after running a load of clothes. We have misplaced the instructions for this washer so cannot figure out how to lift the top to look inside to see if there is something clogging the works. Or can you give us an idea of anything else that might cause this?
  • cdixnad Jan 30, 2009
    have same problem. Doesn't leak on 1st spin cycle but does on the 2nd. discharge hose to main drain is not leaking, nor are the water hose hook ups. Help-please
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    a1 appliance you did good i dont see why gillyn17 gave you such a low rating.sorry about that
  • 61 Answers
With a stiff putty knife you can releace the clips one on each side to lift the top two screws hold the front on fill the machine and advance throught the cycles to see where the water is coming from checkthe hose between the tub and pump with a flash light look between the top of the gear case ( transmition) and the bottom of the tub for water leak if there you need a new transmition and seal kit you are looking at about 200- 250 in parts hopefuly it will be the hose between the tub and pup the is less than 50
Posted on Jan 19, 2009
  • Shawn Smith Jan 23, 2009
    please explane why you think this was an inappropiate solution maybe more details will help tell me what you need to know more clearly
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Washer overflowed, water all over the floor, any
you have a leaking pump and need to replace it.
Sep 14, 2009 | Maytag Performa PAV2200
Water is running all over the floor
u can take a putty knife and push in clips on front panel about an inch in on either side to lift the top remove screws from front panel then u can run it to see where water is coming from
Apr 15, 2009 | Maytag Performa PAV2200
Leaks water on floor and spin cycle very loud
if it sounds like a boeing jet, you will need a new seal & bearing kit. This is something a technician would have to do. many "special" spanner wrenches and spring tools required
Feb 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer performa is over filling with water.
Bad water level switch or pinched hose going to water level switch.
Feb 21, 2009 | Maytag Performa PAV2200
Washer walks across floor no matter what problem.
FIRST OF ALL SCREW THE FRONT LEGS ALL THE WAY DOWN THEN TILT THE MACHINE UP FROM THE BACK MEANING THE BACK SIDE UP SET DOWN FIRMLY THIS WILL AUTOMATICLY SELF LEVEL THE BACK LEGS THEN UNSCREW THE FRONT LEGS TO MAKE LEVEL WITH YOUR FLOOR THIS SCHOULD FIX YOUR PROBLEM THANKS GLAD TO BE OF SERVICE
Feb 03, 2009 | Maytag Performa PAV2200
Maytag LA212 Toploading Washer - leaks as soon as a load is started. Will continue to leak until washer is stopped. Not a small leak - there is a puddle two days later in the floor below it. Removed...
It appears that from that area the problem may be the water inlet valve or it's connections. See diagram https://www.searspartsdirect.com/model-number/LA212/3048/0153000.html?searchType=modelSearch&q=LA212&searchTerm=LA212
Nov 02, 2017 | Maytag Washing Machines
Maytag performa washer
check to see if the tub to pump hose has pulled off
Dec 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
122 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
