Question about Canon ImageCLASS D1120 All-In-One Laser Printer
Check toner connect on canon 1120
Getting error message check toner connect
3 Suggested Answers
MXM450
  • 62 Answers
SOURCE: imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Posted on Jan 26, 2009
SOURCE: Canon IP 4000 unable to connect
hi sir send my smartmovie license key for 355718024819300
Posted on Sep 26, 2012
Why is it indicating black toner is empty?
[Cause]
This may be caused by the Toner ID switch, that contacts the ID PWB on the Toner Bottle. The Toner ID switch has 4 wire contacts, if one of the contacts become crossed over this error may occur.
[Action]
Uncross and straighten the contacts.
If issue remains replace ID Chip Connector Harness [Part Number: G102 1120].
May 02, 2015 | Ricoh Aficio SP C410DN Laser Printer
E000280-0004 and e000025-0200
e000280 is a fan error check this at side door
e000025 is a toner error .an unmatched toner in m/c plz replace with another toner .before u install a new toner clean the devoloper unit
Mar 24, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
E020 01BO What does this error code mean?
E020 indicates a Black Toner malfunction. If you've recently changed the toner and failed to distribute the toner by gently shaking it from side to side, this could be the cause of this error or if the toner is very low it could trigger the same error.
01B0 is a drum error related to your toner error message. If toner cartridge is good, remove the cartridge, clean the drum, replace the cartridge and both errors should clear. A dirty drum will also trigger your 1st error e020.
Nov 16, 2009 | Canon CLC 1120 Color Copier
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
E020 Error message on NP6050
A E020 code is a toner amount problem in the developing ass'y. Is the copier asking for toner or was it and no toner was installed? If not the amount of toner is to low for the hopper to add enough toner in to over ride the toner sensor. Look in the developing ass'y for toner, if you only see about a 1/8' of toner you need to clean or replace the toner sensor. Then you are going to have to run in service mode " toner-s". Then rechk the amount of toner in the developer ass'y. It should be about a 1/2' or so. If not you have a problem with the toner hopper. And if that is the problem you may want to manually add toner in the developing ass'y to get the copier working again. You also have to clear the error code in service mode.
Jan 28, 2008 | Canon CLC 1120 Color Copier
Canon 1120
I don't see where you've indicated the error code. Can't really help unless you describe more of the problem or the error code and any sub code displayed on the LCD display.
Nov 07, 2007 | Canon CLC 1120 Color Copier
Error Message E020, 0400 for canon CLC 1120 Color copier. please give your assitance
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Oct 29, 2007 | Canon CLC 1120 Color Copier
Canon ImageCLASS D1120 All-In-One Laser Printer Logo
746 people viewed this question
old marine
old marine
