Question about Toshiba 51HX94 51 in. Rear Projection HDTV Television
Can i use my toshiba 51H94 hd tv as a monitor for my pc
I need to know if i can connect my tv directly to my pc. it has a ieee 1394 input, thats labled theater net and what is svideo, color stream and where cn i get a cable card
    Genius:
  • 2,920 Answers
You would have to go to a computer shop to get what you need.you should be able to hook into the tv no problem
Posted on Jan 19, 2009
How do i connect my S2410-304 to a tv?
Buy a monitor cable and direct connect .we need to know what kind of tv and what kind of inputs the tv has ...Usb hd or 15 pin .let us know.
Sep 19, 2014 | Toshiba Satellite Computers & Internet
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Connect pc laptop
This TV has a PC interface VGA (HD-15) , so all you need is get a VGA to VGA cable to plug between the VGA output on the PC and TV.
On the PC select the display as external monitor.
On the TV pick the PC input as required input, not the TV tuner.
Here is the manual.
LCD TV 47HL167 Support Toshiba
Jan 05, 2014 | Toshiba REGZA 47HL167 TV
How to connect firewires of the HD?
You just need to plug one end of the firewire (IEEE 1394) cable into the external hard drive and the other end in the slot on the computer marked IEEE 1394. Sometimes you have a IEEE 1394 slot on the front panel, and sometimes it's just on the back of the PC.
If you find you don't have a firewire (IEEE 1394) port on your PC then you will need to get adapter that will change the firewire to a usb. If you have trouble finding one of those then install a card like this in your desktop:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124002&cm_re=usb_to_IEEE_1394-_-15-124-002-_-Product
Jun 21, 2012 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
How to connect firewires?
Good Luck!
WE HAVE NOT CONNECT TO PC MYSamsung VP-D371i MiniDV, Digital Camcorder
From the user manual, I've discovered that you have to use a IEEE 1394 cable (see the jacks display on page 11) to be able to download the movies from your camera. The camera does not come with a IEEE 1394 cable -- it only comes with a USB cable, so you will have to buy the cable.
Unfortunately, most PCs do not come with a IEEE 1394 connector and you have to buy an adapter card for a desktop computer. If you laptop does not have a IEEE 1394 port, then you are out of luck.
Once you have the cable and the port on the computer squared-away, check page 87 of the user manual for directions on how to retrieve the the video from the camera to the computer.
Dec 24, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
What dose the icons mean on front panel what is the little square hole for next to the mike connection
hello, it is most likely a firewire connection.
FireWire, originally created by Apple and later standardized as IEEE-1394, actually preceded USB and had similar goals. The difference is that IEEE-1394 was originally intended for devices working with lots more data -- things like camcorders, DVD players and digital audio equipment. IEEE-1394 and USB share a number of characteristics and differ in some important ways. Here's a summary:
  • Like USB, IEEE-1394 is a serial bus that uses twisted-pair wiring to move data around.
  • However, while USB is limited to 12 megabits per second, IEEE-1394 currently handles up to 400 megabits per second.
  • USB can handle 127 devices per bus, while IEEE-1394 handles 63.
  • Both USB and IEEE-1394 support the concept of a isochronous device -- a device that needs a certain amount of bandwidth for streaming data. This mode is perfect for streaming audio and video data.
  • Both USB and IEEE-1394 allow you to plug and unplug devices at any time.
hope this helps,
regards
Amar Sondhi
Dec 05, 2009 | Medion M3 Director 5100 PC Desktop
TV Guide on screen not loading schedule
I'm afraid this will no longer work... With the change to all digital, the TVGOS in your set will no longer work. I have the same set, same problem and spoke directly with a Toshiba tech. Bummer, I have the Symbio DVR and it won't work now either.
Jun 16, 2009 | Toshiba 51H94 51" Rear Projection HDTV
Driver for IEEE 1394 BUS HOST CONTROLLER
Download Driver Detective and it will reinstall it and do updates for you.
Dec 12, 2007 | Toshiba G15-AV501 Qosmio Notebook
Can I use Firewire to transfer video?
Your computer must be equipped with an IEEE 1394 (Firewire) interface and video capture software. Provided you have both of these, follow the directions below. To connect your digital camcorder to your computer using IEEE1394, follow these steps: 1. Connect the IEEE 1394 interface on your camcorder to the IEEE 1394 interface on your computer. 2. Turn on your computer. 3. Turn on your camcorder. 4. Start the video capture software on the computer. Image capture should begin provided the computer hardware and software are configured correctly. If image capture does not begin, you must consult the computer or capture card manufacturer for assistance. Note: If you don't have an IEEE 1394 interface on your computer, you can buy an IEEE 1394 pci card at your local computer store that will work with most current computers.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Toshiba 51HX94 51 in. Rear Projection HDTV Television Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
