Question about Kenmore HE2 Plus Front Load Washer
Kenmore Washer He2 110-4646 2500
When star is puched add garment anw wash turn on, start the cycle, then both light tur off and all of selection light star blinking and stay there for ever.
  • 1073 Answers
SOURCE: kenmore front load washer
bad door lock switch
Posted on Apr 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite won't start
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Posted on Aug 25, 2008
  • 20 Answers
SOURCE: Pushed pause. Added garment. Washer will not start again.
possible you have not held "start" button down for the required 5 sedonds to restart cycle??
Posted on May 22, 2009
cpldw48
  • 131 Answers
SOURCE: Kenmore He 2 Plus washer door is locked and unable to open
unplug the washer an the door will open
Posted on Apr 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: add garment light stays on after garments are added
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Wash Cycle will not start; ADD GARMENT and DOOR LOCKED lights on.
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
Feb 01, 2014 | Kenmore HE2 Washing Machines
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
May 16, 2009 | Kenmore Elite 45986 Front Load Washer
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Control lock light will not go off.
Do you have any error codes?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F01 and add a garment light on
Check the pump first but you most in likley have a bad circut board. On the front of the washer their is a kick panel. Remove the 3 screws on the bottom and remove it. Taped on the inside is a book of codes and some self diagnostics you can run. This is all your repairman will do and he will order the circut board and charge you more than the washer is worth.
Oct 13, 2008 | Kenmore 46462 Front Load Washer
Kenmore he2
Press and hold the "end of cycle" button for over 3 seconds, it will reset. You will hear a beep.
Dec 25, 2007 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
