Question about Amana AER5515QA Electric Kitchen Range
No burner/oven heating after house power outage.
I recently had a partial electrical outage related to one of the incoming utility lines from the house meter to the electric panel. As a result, certain branch circuits were affected. After utility company came and fixed the problem, all went back to normal, except my free-standing electric range/oven. The lights turn on, but there is no heating generated. Prior to the power outage, the unit worked fine. The unit is an Amanna Self-Cleaning oven, and it's more than 9 years old. I am trying to avoid a) Spending $500 for a new appliance, and B) Local authorized repair service fees of $85 for technician to show up, along with materials+labor costs... Wondering if this is something I can do myself. My guess is the outage triggers a safety device. I cannot see any label with model number.
Try reseting the clock as lots of ovens will not work untill clock is set
Posted on May 26, 2009
Model WOC54E whirlpool microwave/oven combo. recent power outage. microwave works fine. oven display says feature not available for baking when bake button pushed
Hello Carla Christian,
The problem with "power outages" isn't the
out part... it is the VOLTAGE VARIANTS...
Will cause a weak spot to fail... Poor sold joint
or
a transformer... but since you have PARTIAL
functionality you need to look to the specific
are of function that is DEFECTIVE...
I tried you part number but my
parts house wants more numbers...
Take a loo at what I found...
This site also has technical support... AND
VIDEO guides...
They can help you get your WHOLE model number.
http://www.appliancepartspros.com/whirlpool-wide-interface-board-wpw10412514-ap6021091.html
Carnac the Magnificent
May 31, 2017 | Whirlpool Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
My folks recently purchased a house with a Jenn-Air S160 electric grill-range/oven. The left hand side electric burner cartridge's back burner superheats on the low setting. I've switched the burner...
Sounds like the problem is in the control assy. especially if you switched the burnners and the problem remained. Go to the jenn-air website and see if they have a parts breakdown for your unit.
Record the model number of the unit before you search, you will need that info.
Apr 16, 2011 | Microwave Ovens
After recent power outage the oven will not heat up. The back panel lights work etc, but noo heat. Is there a hidden fuse or something that needs to be activated
Make sure that the electronic timer is in manual mode, it needs to be for the oven to work. After a power outage it normally reverts back to auto. mode.
Feb 17, 2011 | Maytag PER5710 Performa Electric Kitchen...
My stove will not heat up
The stove has its own fuse so that even thought the rest of the house is OK then the stove could still be dead.
Have you checked your fuses?
Jan 08, 2009 | Whirlpool RF3020 Electric Kitchen Range
Top burners and oven don't heat up enough-GE Spectra
the stove it's only getting 110 volts, that's what happen when it does not get enught power.
Dec 03, 2008 | GE Spectra JBP78 Electric Kitchen Range
Burners not working and stove only heating up to MAYBE 100 degrees
Had a similar problem...it was the power coming into the house and the ground wire was badly connected. The power company checked out the lines feeding the house and discovered the problem. Its caused by the fact you are trying to heat the stove with only one line...when, you need two. Check the house circuitry.
Jul 16, 2008 | Frigidaire FEF364DQ Electric Kitchen Range
Partial Power Outage
This could be very dangerous.
I would first call your electric company and ask if they have any problems with their lines, etc. We recently had this problem at our home and it was in their circuits.
My mother in law had a similar problem and we caught it in time. In her house, several outlets showed extremely low voltage and the others showed extremely high voltage.
It turned out to be a bad neutral connection on the line going from the pole to the house. The electric company fixed it at no charge.
Also, you or someone you know should measure the voltages coming out of your outlets, or call an electrician right away.
You may have a loose circuit breaker or a bad connection somewhere your electrical panel or elsewhere in your neutral line.
This can lead to destruction of your appliances or even a fire, so please don't delay.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 16, 2008 | Hotpoint RVM1435 Microwave Oven
Amana AER5515QA Electric Kitchen Range Logo
465 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
