Question about Frigidaire GLWS1649A Top Load Washer
Agitating to many times
Washer fills up agitates water slowly goes out then it adds more water and starts to fill up again then agitates again and does this over and over. If I move knob to spin some times it does some times it dont
  • 5,911 Answers
Have you verified that you do not have a siphoning condition? The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Please double check the installation and placement of your drain hose. If the top of the standpipe is sealed off, or if the drain hose is shoved too far down into the standpipe, this can create a vacuum. This can cause the washer to constantly siphon out of the wash tub on the fill cycle and the washer will continue to fill (as needed) to maintain the water level. In other words, what may appear to be a significant problem, can be something as simple as a simple placement issue with the drain hose.
If you have further questions, please let me know. If the diagnosis is not correct, please post back and also let me know, so that I may be able to assist you further. I hope this helps you.
Posted on Jan 21, 2009
The washer starts in agitation mode. Will not do anything but agitate. Is it Water Level switch that needs to be replaced?
Washers start in fill mode as it requires the level of water set to start the agitator mode.. If your machine goes immediately to agitate then I would think that the agitator control module is failed and needs replacement. have an appliance electrician check it out.
Aug 17, 2013 | GE WDSR2080D Top Load Washer
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer functions but doesn't fill with water, with
if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
replace the water level/fill switch for the fix.
Phil
Jun 10, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator will not agitate. Also water trickles in instead of flowing in like a tap turned on. Also water leaking under from pipe that goes into plastic component - looking from back of machine bottom...
  • the agitator has a set screw in the side of it about half way down. this may have rusted out or fallen out.
  • the transmissions may be failing (unlikely)
  • the water inlet valves (where you connect the hoses to the washer) have screens in them, they might be clogged causing the water to slowly drip in.
  • the water leak is most likely caused by a rusted clamp loosing its pressure on the hose.
  • the plastic component is the water pump
  • it might be time for a new washer
Jun 28, 2008 | Maytag Washing Machines
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire GLWS1649A Top Load Washer Logo
56 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
