Question about Linksys (WRT54GC) Router
System fails to connect to each other
It has worked in the past, but connecting cords and disconnecting fails to get it to connect to the 2nd computer.
  • horanm Jan 19, 2009
    Thle solution failed to work. Canl I have a refund of the $9.99?
  • 916 Answers
Please let us know what other devices are you trying to connect to the router? and what operating systems are the machines running?
Posted on Jan 19, 2009
    Genius:
  • 2,920 Answers
Have you tried shutting the computer down and then hooking it all up and rebooting it that way to see if it wont find the router?
  • 837 Answers
Check that the firewall settings on each PC have not been turned on. That will prevent access.
    Genius:
  • 1,011 Answers
Sir,
Check these link for "How to connect the computer with other computer"
Link 1
Link 2
Thanks
Good Luck
    Genius:
  • 1,550 Answers
Check the router settings .
Also check the firewall settings.
  • 13,433 Answers
Press and hold the reset button for 30 seconds to restore the router to default settings and try again, report back by commenting on the results.
Thanks,.
  • Ekse Jan 19, 2009
    Please provide us with more details of the problem, what system are connected to the router and how?
    What is the actual problem? please be spesific as to what you are trying to do and what happens when you attempt to do so.
    I really am not a mind reader.
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
HP T1100 post script getting 08:11 error, which means communication with front panel, but have read it could be all sorts of different problems. Does anyone have experience with this? Before this error I...
This comes straight from the service manual:
System Error: 08:YZ
Problem Description: Problem with the Front Panel.
Corrective Action: Try the following:
1 Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2 Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel. (they can easily become partially disconnected)
3 Check that the memory module in the Formatter is installed correctly.
4 Check that the connections between the Formatter are not damaged and are correctly connected.
5 Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
1st If the System Error continues, replace the Main PCA
2nd If the System Error continues, replace the Formatter
3rd If the System Error continues, replace the Front Panel
Sep 13, 2013 | HP Designjet T610 InkJet Printer
4gb usb cannot be detected on my computer. how to fix the problem?
Try it on the other pc just to see if its working atleast,if yes then try it back to your PC but using different usb port.or also go to my computer management then check your Universal serial bus controllers if not showing any errors rght click on them and scan for Plug and Play complaint components.
Sep 04, 2011 | HP Computers & Internet
Printer was stuck in "offline" mode, so deleted it
This is not Printer or PC USB port issue.
You need to drain the power from PC.
Follow these steps to resolve the issue
1. Disconnect the printer power cord from walljack or surge protector
2. Disconnect the USB cable of printer from PC or vice versa
3. Power off your PC, Disconnect the power cord from wall jack
4. Wait for 5-10 mins
5. Connect the PC power cord and power on the PC and wait till you are able to login to your PC
6. Connect the Printer power cord
7. Connect the USB cable to PC or vice versa you disconnected.
This should resolve the issue.
Oct 29, 2010 | HP DeskJet 5150 InkJet Printer
I have a kx-t7630 digital phone but if i connect it to the dhlc card in a panasonic kx-tda200 i won't work.. but if i connect analog phones it works.
Check the wiring. The cable that plugs into the DHLC is designed to be compatible with the TD series systems which means the first two of every 3 pairs is used for the 8 extensions. The 2nd pair has to be wired and jumpered for a digital phone to work. I'm guessing all other Pana analog or digital phoens would fail too.
Carl
Oct 05, 2010 | Panasonic KX-T7630 Corded Phone
Tv blown fuse repeatedly
There is short circuit in your system. Check the wall socket,plug and the power cord. Disconnect the power cord and connect it after checking it. If this fails then the fault lies inside the TV for that you may have to take assistance of service technician in your area.
Jan 14, 2010 | Toshiba 32A33 32" TV
LCD monitor (viewsonic va720) "No signal"
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
Jan 05, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Won't boot
Turn it off.
Disconnect the AC power-cord.
Disconnect all the devices (floppy, disk-drive, CD-ROM).
Remove all "extra"add-on cards (modem, network, TV, 2nd video).
Remove all the RAM.
Connect the AC power-cord.
Turn it on.
Does it "beep", to complain that _NO_ RAM is available?
If not, the motherboard is "dead".
Oct 08, 2009 | Compaq Armada M700 Motherboard
Looking for cord to connect main unit to 2nd screen.
go to www,18002526123.com they sell accessories and replacement parts for this system
Jan 07, 2009 | Durabrand Two Screen Car DVD Player
Error OPxc18a401
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Nov 19, 2008 | HP Photosmart C5180 All-In-One InkJet...
Open Questions:
Linksys (WRT54GC) Router Logo
14 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
