Question about KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator
French Door to right swing on Fridge
OK - I bought a KitchenAid KBFA20ER model fridge for the newly remodeled kitchen. It has french doors and a bottom mount freezer. Is there anyway I could convert this to just a right swing? (if i was able to find a door available)
  • Anonymous Mar 25, 2014
    French door how to limit door swing
  • Anonymous Mar 30, 2014
    you have to close the left door initially before the right door
  • 944 Answers
Go to this link and you can see all the identical sized models with a right swing door. The hinges are the same so you could easily swap them; http://www.kitchenaid.com/catalog/category.jsp?categoryId=77#85 here's a link to the user manual if you need it; http://www.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202300253.pdf check page 7 and 8 for how to swap a door. Page 20 gives you contact details for spare parts. Hope this helps :)
Posted on Jun 27, 2007
The door flap on my KitchenAid French Door fridge isn't springing completely back into place, and it's catching on the other door.
Locate and adjust the spring responsible for getting that flap into proper place and all will be resolved.
Aug 30, 2015 | KitchenAid Refrigerators
Fridge leaks from freezer
Sounds as drain is plugged. Remove rear cover in the freezer and check drain . Also clean drain pipe in the fridge at the top part and clear drain tube
Aug 26, 2014 | KitchenAid Kitchen Aid 19.8 Cu. Ft....
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Nov 16, 2013 | Samsung RF265AA Bottom Freezer French Door...
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
One door pops open when opposite side is closed
it can as the air inside is pushed by one door pushing the other. if it popsit open and stays open, level the fridge backwards.
Feb 07, 2010 | KitchenAid KBFA20ER Bottom Freezer French...
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
LG Fridge...door strickers
here is a link to an exploded view of your fridge model.. which parts are you looking for? Perhaps your description of the part differs from mine.. what is the part you need? Please be specific so I can assist you in finding a supplier...
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Exploded.pdf
Aug 10, 2008 | LG LFX25960ST Stainless Steel French Door...
Refridgerator (Bottom Frzr-French Door) not getting cold....Freezer is o.k.
could be a few issues, id open teh freezerdoor at looka t back panel id tere frost building up??? if so youhave a defrost issue, can you here the fan in freezer conmpartment spinning you may have a bad evap fan
Mar 16, 2008 | KitchenAid KBFA20ER Bottom Freezer French...
KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator Logo
307 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
