Software pc charge 5.7.1 security code
Am running PC Charge 5.7.1 that is unable to be upgraded due to it being in a very old kiosk and cannot be upgraded. Unfortunately the gentlemen that use to support us died expectantly. I am trying to change the merchant provider, however I need a security code. Unfortunately pc charge will not support unless i upgrade to a newer version and my system will not work if I upgrade the software. Does anyone know a generic security code that will allow me to change my merchant provider?
Battrery will not charge
Laptop Battrery will not charge
Mar 03, 2014 | Acer Aspire 5253
Pc charge 5.7.1 security code
Hello
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 04, 2013 | Cell Phones
My computer says it does not recognize my battery so will be unable to charge it. I unplugged my adapter for a bit and then plugged it back in. My battery is showing 94% and has not charged to 100% since...
How old is the battery and is it charged as you use the laptop all of the time because if it is and it's more than 6months old then it could be faulty now due to the chemical reactions.
Jan 01, 2011 | Dell Studio 15 Laptop
Unknown device...will charge temporarly on pc...no sync itunes
you can go to start menu, then run, type regedit then find H KEY LOCAL USER and expand it, find unknown device, right click and delete it.
you will need to do the same with H KEY LOCAL MACHINE.
Oct 10, 2009 | Apple iPod MA446LL/A MP3 Player
Error 3343 when I start PC Charge, how can I fix this?
error 3343 is a database error. Unfortunately, PCCharge is still in the stone-ages of computer technology and they think VB6.0 and MS Access 2.0 are stable and secure ... At any rate. 3343 is simply an unrecognizable database, in this case due to corruption. There is a program in the PCCharge directory called VisData. This will allow you to run a repair and compact the database. To use:
First make a backup of your PCCW.MDB database in your PCCharge directory (C:\Program Files\Active-Charge (PaymentServer); C:\Program
Files\PCCW (PRO)).
Execute VISDATA.exe.
File -> Repair MDB.
Select the PCCW.MDB database from your PCCharge directory.
Select 'No" to open Repaired Database.
File -> Compact MDB ... 2.0 MDB
Again, Select the PCCW.MDB
It will then prompt for what you want the database to be named. Simply select PCCW.MDB again, select 'YES' to replace existing database.
Select 'NO' to encrypt database.
Select 'NO' to Open Compacted database
Exit Visdata and start PCCharge.
It would also be a good idea to go ahead and update to the latest available Scripting Runtime library. This can be found by going to microsoft.com and searching for the phrase 'windows script'. (To my knowledge, 5.7 is the latest version).
Jul 16, 2009 | Go Software Inc. PCCharge Pro...
L7 unable to charge
All cellphone run on Lithium Ion batteries. These batteries, by nature(physics) have a max charged voltage of 3.4 to 4VDC. So, of your charger, or USB cable, has less than about 5 VDC, then either charger is defective, USB cable(if charging from PC USB port) is not a FULL USB(has data leads only wire, 5V power wire not carried through, PC does not supply 5V power to USB because it is turned off by a PC setting option, or a non-powering USB Hub or other device is in series with PC and Phone.
Are you sure you have identified the GND wire correctly? Measurements must all be made with one lead of your VoltMeter referenced to GND. Another consideration, some Windows Mobile phones will not charge off the USB cable unless the latest version of WM ActiveSync or Mobile Device software is loaded and running on the PC. These WM phones also will not charge from just any AC USB generic charger. Charger has to be for that particular phone, or phone manufacture, to be 'recognized' before provideing charge.
The
Feb 20, 2009 | Motorola Mobility V710
Charging pin of my ipaq damaged
hi
I can fix your sync&charge connector very fast in our lab.
you can send your device to us and we will charge you by paypal and return it to you in less than one week.
thanks
Gery
ipaq Lab
Nov 27, 2008 | HP iPAQ hw6515 Pocket PC
Downloading flashplayer
IT IS SOLVED
Follow the steps
1. Click on the below link ::
http://www.softwarepatch.com/network-security/flashplay-security.html
2. Wait for 5-10 seconds
3.One pop up will come under the address bar Click on that pop up
4. And then click on download file
5. Wait, and it will ask u about run a file or saving the file
Happy Flashing.
If problem remains den tell me in detail your problem will be get solved
Aug 30, 2008 | Macromedia Flash MX
Charge by usb cable
When we connect the phone to PC it automatically start charging but after 5 mins it stops its because we do not take any kind of action i.e. if you will send some files to phone or will operate phone from PC it will keep charging otherwise as you have said it will stop.
Jan 17, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
