Question about Stoves Newhome ECH600MXa Electric Kitchen Range
My new home 800df dom double oven has a problem, i noticed the bulb in the bottom oven had blown on further investigation i noticed the oven is not heating up at all, although the fan works fine, would the bulb stop the oven working if blown?
  • Anonymous Feb 01, 2009
    same issue, I think it might be either the thermostat sensor in the oven or more likely the element.
  • carolepolloc Feb 28, 2009
    hi
    yes I have the same prob
    my bulb s gone, an oven not working, but fan is
    dont know if its the thermastat or element,
    have you sorted yours out,
    thanks carole
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: De Dietrich double-oven; smaller oven
Check the information on this link.
Posted on Jul 22, 2008
  • 3 Answers
SOURCE: Top oven thermostat Stoves 800DF - fitting?
you dont need to remove the front panel, you need to undo the two black screws on the side of the hob unit, remove the two plastic plugs they went through allowing you to raise the hob, and remove just the back off the cooker this provides you access to all the areas you need you can then follow where all the cables go oh yes nearly forgot the thermostat is held in place by two screws you simply pull the knob off and there they are. ive just done the fan oven one and it seemed fairly straight forward, but please do remember to turn off the power to the cooker first all the connections push on using spade connectors, oh yes for legal reasons this is for information only and i wont be held liable for injury or damage caused by unqualified people following this information to fix it themselves as i would always have to recommend that you use a competant person ie a person who is trained, experienced and has sufficient knowledge to do the job, but those that do want to fix it do so at their own risk and i hope all goes well with getting the problem fixed
Posted on Mar 27, 2010
  • 3 Answers
SOURCE: i need to replace the top oven thermostat control
How to change a light bulb on my Frigidaire oven model RT 70 light bulb in the signal light area in the surface unit switch?
Hello Heidi, thanks you for your inquiry!
From the information you have provided you need to change the light bulb inside of your Frigidaire Imperial Electric Range. This appears to be an older model and I was unable to locate any direct information on how to change a bulb. Since your appliance is older than ten years old the manufacturer may not have any information for it. You may need to perform a generic search online for further help with the bulbs or speak with a local technician. I hope this information is helpful. -Matt
Jun 02, 2015 | Frigidaire Kitchen Ranges
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
Jan 03, 2015 | Maytag Gemini 30" Self-Cleaning...
Jenn-Air dual fuel double oven range - oven wont work.
You can make the repair yourself. What is the model number?
Nov 07, 2012 | Jenn-Air Kitchen Ranges
I need to replace the top oven thermostat control how do i remove the front panel ???oven is a stoves 800DF DOm 050565031
Feb 15, 2010 | Stoves 800DFDOm Dual Fuel (Electric and...
I have an old double oven white -westinghouse stove and while i was at work the fuse blew in the basment. well i have reset it but now everything works but my stove. well my oven light will not come on...
Hi, sounds like your oven is a 240 volt electric.  One of your fuses is still blown. 240 volts requires 2 hot legs and obviously you have only one. When you turn on a burner, it completes the circuit to your light. Bottom line, you only have 120 volts to your oven, check the breakers or fuses. Good luck!
Jan 29, 2010 | Kitchen Ranges
Hi, we have had one of these ovens for 8 years (it was in the house we moved into). We had a new control fitted for the top oven (it took the repair company three tries to get the right part) and the problem didn't go away. To be honest, we can't stand this oven but are waiting until we replace the entire kitchen to replace it. The bottom oven is fine. The top oven is fierce and burns food all the time. Overall it's a ridiculous oven - I'd much prefer a sensibly-sized one that actually worked well! Rant over.
Jun 10, 2009 | Stoves 800DFDOm Dual Fuel (Electric and...
Need a part
if the glass have no holes for the handle goin true, you can take it to any glass company near you. it can be made with a smoke glass. it does not have to be temper glass for the out side.
Dec 07, 2008 | Kitchen Ranges
Oven light problem
sure you can use with out back cover, sounds as if connection inside socket is loose( not making contact with bottom of light bulb securely
Feb 10, 2008 | Whirlpool RF368 Electric Kitchen Range
Stoves newhome
the residue is the grease being exhuasted from the oven.i wouldnt think you could vent it out unless you have an overhead hood.if its really bothersome look at a home depot/lowes for a heat/fire resistant filter and install it on the oven somehow.
Jan 05, 2008 | Stoves 800DFDOm Dual Fuel (Electric and...
Stoves Newhome ECH600MXa Electric Kitchen Range Logo
236 people viewed this question
Top Stoves Kitchen Ranges Experts
paulcarew
Ismael Rodriguez...
Bargain Box
Bargain Box
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
