Question about Rinnai RU98iN Water Heater,tankless,3/4 In,natural 20K868
Rinnia Dip Switch Settings
What are proper dip switch settings
2 Suggested Answers
SOURCE: Dip switch settings for Rinnai V1200 & V1500
curios to find out if you had any help on this subjuct at all?
Posted on Aug 01, 2010
Can Richmond tankless heater which is now LP be converted to natural gas?
If it can, then it is done with dip switch settings.
Read your product manual.
Switching types of gas, and messing with dip switches is dangerous.
LP gas burns much hotter than NG, and LP pressures are much higher than NG
Call Rheem with serial number and they might supply the information to you, but will likely tell you to call service technician... leaving you in exact same spot you are in now.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Sep 29, 2014 | Rheem Richmond Encore Tankless LP Gas...
Convert to LP
Often tankless conversion to different gas is done with dip switch settings
Check product manual
Call service technician
Call Rheem
Gene
Aug 22, 2014 | Water Heaters
ARE THERE INSTRUCTIONS
Call Rheem... and they might suggest local technician, or give you correct instructions and dip switch settings if that applies.
Otherwise Rheem does not post service manuals
Gene
Water Heater Timers Save Money
Jun 20, 2014 | Rheem RTG20214D Liquid Propane Commercial...
Change dip switch setting and were are the located ?
Dip switches are located on the circuit board.
These switches are for changing temperature and altitude etc, and depending on brand and model, the switches settings are different.
Oct 16, 2012 | Rinnai R98LSiN
Rheem RTG53DVP code 82
Before calling service technician, open following link for resources including error codes, Rheem chat and possible manual:
Error codes are considered start-point for troubleshooting, and give service technician direction for isolating problem.
Error 82 appears as 'gas type data failure' > 'Program PC board for proper gas type.'
Gas type is choice between LP gas and NG natural gas.
Gas type programming is controlled with dip switch setting.
I do not have service manual for product, and would not suggest changing dip switches without specific information beforehand.
Aug 16, 2011 | Rheem RTG53DVP Direct Vent Liquid Propane...
Only heats water to 1oo degrees and temp on remote is set at 140 ?
I just changed mine today with help from Rheem support as the manual had a typo error.
You should be able to increse to 120 max as default. However if you want to change to 140, you will have to perform the following as detailed in the manual ...
- Turn off the power.
- Remove the cover.
- There is a dip switch on the controller board. Flip dip switch #4 to "ON". Your remotw will start flashing.
- Press SW2 on the controller board for at lease a couple of seconds (The manual states SW1 which is incorrect)
- Flip dip swich #4 back to "OFF"
- close cover
- Turn on heater ... you should be able to adjust up to 140.
Dec 31, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Aug 24, 2009 | Rinnai Water Heaters
-0 82 error code PTG-74PVN Rheem tankless
I had the same problem, but when you change the PCB the chip has to be reset regardles of the elevation so it can communicate properly. The rest is easy, Find the DIP Switch located on the top left side of the PCB set switch #1 & #2 to the ON position push and hold the adjustment buttom till the display changes from flashing to illuminating the reset the DIP switch #1 & #2 to the OFF position and you are ready to go.
Aug 21, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My Rheem Tankless Hot Water Heater is installed, but is it not attempting to start. The digital display keeps blinking 82, 0, 82 , 0 ...?
If this is a new board and Altidude chip with power on set dip switch 1 and 2 to on. Then press and hold adjust button until on board blinks fast then and you will see dashes on LCD display. Set dip switches 1 and 2 back to off. Turn on remote unit and you should see 100F. With any luck you are good to go.
May 02, 2009 | Rheem Tankless Hot Water Heater...
Limited hot water output
are both heating element getting electricity?  Are they both good?  Are the temp settings on both the same?
Mar 15, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rinnai RU98iN Water Heater,tankless,3/4 In,natural 20K868 Logo
32 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
