Question about iRiver PMC-120 Digital Media Player
Not recognized by my Win XP SP2 computer
My laptop recognized the device 4 days ago and I was able to remove all but a few of the MP3s stored on it, as well as half of the movies. Problem is, I removed these files using Windows Explorer (the device acting as a hard drive) then tried to sync with WMP11. No luck - no files were transferred. Attempted to transfer for 2 hours, gave up and the next day asked a tech friend for help. He gave up after not finding drivers - wouldn't even try it on his 2nd or third computers, each with a different config! (Sorry, ticked about that) Now when I connect it to my laptop I get "found new hardware mtp device" but it doesn't find the iriver. I've taken out the battery, hit the reset button a couple times, no luck. Also tried a different USB cable with a connection that fit the player. Tried running it as the only USB device installed. None of the above worked.
    Problem Solver:
  • 11 Answers
You probably erased some of the players system configuration files in the process of your file removal. You might want to reformat the device by going to my computer and right clicking of reforamt this device. Once completed you might want to unistall the device as well and make a complete fresh install of it by either installing the driver again using the players website download or the cd that came with you player. To unistall the device do the following: 1)Go to start 2)Right click on my computer and select properties. 3)Once there go to the device manager tab. 4)make sure it is connected 5)Find your device and right click and click uninstall. 6)After just restart your system and install the driver again for your player or insert the Cd another alternative would be instead of uninstalling is to check for a device update.
Posted on Jul 23, 2007
  • 944 Answers
Check this thread; http://www.fixya.com/support/t156529-laptop_found_new_hardware_mtp_device :)
Posted on Jun 27, 2007
2 Suggested Answers
SOURCE:
MakikiChris
  • 84 Answers
SOURCE: My laptop does the "found new hardware, mtp device" popup, but doesn't recognize it as iRiver
Hi venussuz...The driver for the 100 Series can be downloaded by clicking on the Following URL....good luck my friend http://www.iriver.com/support/down_ok.asp?idx=3140
Posted on Aug 03, 2007
Hey, i recently reformatted my mx6453 so im back to the old win xp sp2. reinstalled all my drivers but for some reason it won't recognize an internet connection of any kind. at first i though it w
If your driver are ok then is your computer is in same WORKGROUP like other are(If you are in LAN connection and sharing internet with other).
was there any IP address in your computer before you formatted it? make it confirm and if IP was there then give back the IP to tour connection.
Aug 08, 2012 | Gateway MX6453 Notebook
Here's the link for the user manual if you need it; http://www.iriveramerica.com/download/pmc/PMC-100.pdf check page 137 of the pdf and try the restore to original settings. do you have the setup cd? - it has troubleshooting for the unit, which is not available on the website there are no drivers available, it uses windows media player as a driver, but the manual and the support site; http://www.iriveramerica.com/support/multi/pmc100_faq.aspx both claim that you need windows media player 10, not 11 to synchronise. you can download it from this link; http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx or install it from the setup cd just uninstall wmp11 first. many of this type of unit and mp3 players etc have problems with wmp 11, hopefully reverting to 10 will allow you to sync Hope this helps :)
Jun 27, 2007 | iRiver PMC-120 Digital Media Player
Front buttons don't work on CF-19 (MK2) After upgrade from xp sp2 to xp sp3!
From the description, the laptop will only support SP2 the only suggestion I can offer is format the hard drive and reload your original disc to get the front controls back.
Apr 26, 2012 | Panasonic Computers & Internet
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
HDD81830/17
Uninstall all Philips software through the Add/Remove Programs function.
Then reinstall the installation CD.
Then and only then, plug your mp3 player into the computer.
Oct 07, 2008 | Philips GoGear HDD1830 MP3 Player
Unable to install XP sp2 on Intel D865GBF Motherboard
Maybe having trouble with a device, remove any pci or agp cards and usb devices, use built-in video until installed.
Set bios to defaults, make sure bios is latest version.
I have found this happens with a promise ultra-100tx2 and any nvidia video card.
May be a bad install cd, if you can boot it with a dos or win98 disk/CD, copy xp i386 folder to hard drive install from i386 folder on hdd by running winnt.exe
I have installed xpsp2 on about 10 d865gbf's and 2 days ago installed xp sp3 on one with no problems. may also be bad mobo.
Jun 28, 2008 | Intel D865GBF Motherboard
Labtec Wireless desktop 1200 not working- win xp sp2
Seen to be a problem with power manager.
On Linux the solution what
echo -1 >/sys/module/usbcore/parameters/autosuspend
I find it here:
http://www.linuxquestions.org/questions/linux-hardware-18/usb-error-usb-2-4-device-descriptor-read64-error-71-643022/
Apr 26, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Compaq C733TU audio driver for windows XP sp2
i have compaq 772TUlaptop
i formated my laptop bt now want to download d audio from net
hw to do
Jan 21, 2008 | Compaq Presario 700 470024-192 Notebook
USB will not recognize devices
just try to first install your device driver in xp-home sp2 and then try if not pllz ask me.
Dec 25, 2007 | Dell Dimension 4500 PC Desktop
Open Questions:
pmc 120 when i set up a sync list on media player and start to sync it to the pmc, it works sometimes, other times it aborts. it gives me the message "you can now disconnect iriver Portable media centre" when i try to do it again it tell me Windows Media Player encountered a problem while synchronizing the file to the device. For additional assistance, click Web Help. when i go to th web help it explains the problem as You've encountered error message C00D1236 while using Windows Media Player. The following information might help you troubleshoot the issue. Cannot sync the file Windows Media Player encountered a problem while synchronizing the file to the portable device. Because this error can occur for a variety of reasons, there is no single solution. To resolve the problem, try disconnecting and resetting the device. See your device owner's manual for specific instructions on performing this procedure. In some cases, this error can occur if you try to sync a hidden file to a device. To resolve this problem, either remove the file from the sync list or change the file's properties so that the file is not hidden. Also the error details are Technical Details This error might have been triggered by an error in another program or component of Windows. The following information describes the original error. Original Error Code Original Error Message C00D1179Windows Media Player does not detect a portable device. Connect your portable device, and then try again. So im not sure why it keeps aborting. if you can tell me your views on this please do. Other information that may be useful i tried formatting the unit : 1. Through windows media player 2. through explorer the pmc is supposed to be used with windows media player 10. i had wmp 11 originally and it didnt really work too well. i rolled back to 10 and it worked better but still not consistantly. i tried installing wmp11 again and now the Pmc120 will abort after about 3 songs of an album i would have setup to sync. thanks for your help. Gavan Doran. Ireland.
Oct 16, 2007 | iRiver PMC-120 Digital Media Player
iRiver PMC-120 Digital Media Player Logo
313 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
