Question about Intel PRO/Wireless 2200BG 802.11g/b
Hi there... i have a COMPAQ Presario R3000 the wireless button on the corner of the laptop does not seem to be working i want to turn the wireless on ( wireless is built in to the laptop)
  • 24 Answers
There is a mechanical problem with the R3000 buttons, (especially the wireless button) where they seem to push fine but are in fact failing to make electrical contact. I know of two work-arounds.
* Try pushing the button with a capped pen, gently at first, and then with increasing pressure. (Not so hard you break the plastic, please!) I suspect this gives the buttons just enough extra "oomph" that contact is established.
OR
* Push up on the battery compartment while pressing the buttons. If the battery is in, you can acheive this same effect by putting your laptop on a table and popping up the screen, then applying downwards pressure on that corner of the laptop body while pushing the button. I suspect this aligns things properly so that the button is able to depress just a hair further.
You may even find that these actions "loosen things up" enough to cause the buttons to work like new for a little while. I hope this works for anyone reading this!
Posted on Sep 11, 2010
  • 39 Answers
Hello
Try rebooting and pressing F2 (If F2 doesnt work try F10) and seeing if there is an option OR rebooting and pressing F12 and then running windows normally. I hope this helps
Best wishes :]
Posted on Jan 19, 2009
  • 52 Answers
Well..if the switch is not working u will need to replace the switch..no software willl fix this....if the switch is fine and there is no light coming on well try update bios/system restore/-check to see if the adapter is listed under device manager
Hi i have a vsx 7000 for sale with out subwoofer ,my son nock drink on it ,want to sell with remote and mic any one intrested
How do i turn on my wireless capabilities on my presario compaq laptop
hi
press the wireless button until it shows your wireless device enabled
Dec 09, 2010 | Compaq Presario R3000 Notebook
Where is the wireless switch on the compaq presario laptop
It is usually on the right front corner, just below the edge of the cover/screen. Look at the laptop from the front, and follow the edge all the way to the right. At the very corner of the right front of this laptop, you will see a tiny icon in blue and silver. Push it in once, and to its right, there will be a blue and silver icon light up. That is your wireless switch.
-a.
Dec 15, 2009 | Compaq Presario R3000 Notebook
Where is my wireless switch on my Compaq Presario R3000
Right side in the front at the corner ,,little round button ,,it will glow blue when on,,
Dec 13, 2009 | Compaq Presario R3000 Notebook
Enabling wireless connection on Presario R3000
Windows XP
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=442914
Networking Drivers And Utilities Can Be Found Under "Network-Driver"
Go to device manager (Right click my computer , properties , hardware , device manager) and check for any devices listed with a yellow ! next to them
Download and install the wireless driver or alternatively right click the device with the yellow ! and click update driver. The wizard then guides you through the steps of searching for and installing the correct wireless Lan driver.
When finished , check to see if the connection has appeared , either at the bottom near the clock or in the network connections area (access from control panel)
If yes - Problem Solved!
If no - Download the Correct wireless lan utility from the link above that corresponds with the driver you downloaded.
install the utility and load it to see if it detects any wireless points
Dec 10, 2008 | Compaq Presario R3000 Notebook
Where is wireless connection switch on Compaq Presario R3000?
Well if u have the same exact one as myself.
The wireless button is on the front right near the corner. above it and on the corner is the wireless symbol. If its working it should be lit blue. push it and see if it lights up blue for a few seconds. You should get a wireless connection confirmation on the screen.
hope this helps you
Nov 10, 2008 | Compaq Presario R3000 Notebook
Cant find my wireless button
it must a combination of fn and windows key
Nov 03, 2008 | Compaq Presario R3000 Notebook
Compaq presario wireless button no longer working
There is a mechanical problem with the R3000 wireless button and volume-down button where they seem to push fine but are in fact failing to make electrical contact. I know of two work-arounds.
OR
Oct 03, 2008 | Compaq Presario R3000 Notebook
Presario r3000 wireless not working nor is light on
If your volume buttons don't work either this should help. Place your laptop on a table and press down on the lower right of the computer(under the arrows near the microphone and headphone symbol) or clamp down on the battery compartment (center). The blue light on the corner should illuminate, if it's off press the network button while putting pressure(the indented one on the right front edge) you shoud hear a double ping sound. I put a thick felt pad between the battery and the computer and now everthing works. I know it sounds really STUPID but it works.
GOOD LUCK
Richard.
May 04, 2008 | Compaq Presario R3000 Notebook
No wireless connection with laptop Presario R3000 (anymore!)
If your volume buttons don't work either this should help. Place your laptop on a table and press down on the lower right of the computer(under the arrows near the microphone and headphone symbol) or clamp down on the battery compartment (center). The blue light on the corner should illuminate, if it's off press the network button while putting pressure(the indented one on the right front edge) you shoud hear a double ping sound. I put a thick felt pad between the battery and the computer andnow everthing works. I know it sounds really STUPID but it works.
GOOD LUCK
Richard.
Apr 15, 2008 | Compaq Presario R3000 Notebook
Intel PRO/Wireless 2200BG 802.11g/b Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
