Question about Health & Beauty
My TaoTao ATM-50 49cc scooter wont start.
Recently my carb had a broken part and it was leaking gasoline. Soon after I fixed the leak it stopped working. So i replaced the carb and now it still wont start. I checked spark and it had a spark, I checked air and even took off intake hose. I tried to see with bag if fuel line has suction and if gas gets to the carb. I have checked the vavle setting and reset it to factory setting. I have noticed that it used to turn and spark but would not run, now after all the trial it just sounds like it sparks but wont turn, due to weak battery. I have tried kick starting many times and still nothing happens. plz help!!!! My scooter does have a electric start and kill switch. And i have started it with kickstand down before.
  • 1 more comment
  • havico
    havico Jan 04, 2013
    May I add it only has 800 miles or so and is fully Automatic.
  • havico
    havico Jan 05, 2013
    Currently charging battery back to full, and I checked fuel line filter which had way to little gasoline in it so I flooded it a little more so it can suck fuel better. After battery is done charging I will try to start it. If it doesnt work I will try another compression test. IDK what else to do this is my only transport.
  • havico
    havico Jan 06, 2013
    fixed it myself, was due to to much air in fuel line.
5 Suggested Answers
  • 41 Answers
SOURCE: Yamaha vino 50 cc scooter
hello, check to see if it is a switch (pull hand brake back when starting
Posted on Nov 25, 2008
picatudo
  • 239 Answers
SOURCE: Chainsaw is extremely hard to start and won't stay running.
adjust the two little screws on the carburator
Posted on Dec 31, 2008
  • 3567 Answers
SOURCE: 1998 Honda Goldwing will not start nothing.
Sort of sounds like a Twilight Zone kind of problem doesn't it. I would have the battery checked for an internal dead short. This is something that happens on odd occasions and can happen even to a new battery. Yea, the little lights will work ( they do not draw much juice ), but the starter motor draws a lot of juice and a shorted battery just ain't got it. Also check the wiring harness connections. One loose connection can cause bunches of trouble.
Posted on Mar 14, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
Posted on Jun 08, 2009
TaoTao 50 will not idle
Hi, Misty you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the choke off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air-fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air-fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air-fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air-fuel mixture skrew can acquire without going past 3 full turns from the bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bought China scooter Won idle properly scooters
Tao Tao 50cc scooter idle problem fix
My chinese scooter wont idle or start Check the fuel petcock http://www.family-motorsports.net/GY6-50cc-150cc.pdf
TaoTao 49cc Scooter Parts
TaoTao ATM50 A1 Owner Manual
Mar 29, 2018 | Motorcycles
How to replace vacuum line on tao tao 50 scooter
Hi, Brad for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your TaoTao, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Taotao ATM150 Evo scooter replacement of fuel and vacuum lines
Taotao ATM150 Evo scooter fuel tank vent line gas leak fix
http://absolutelyscooterparts.net/pdf/CGen_GY6_50cc_Service_Manual.pdf
Eagle Atv Parts
Dec 01, 2016 | TaoTao Manufacturer Inc Motorsports
What is wrong when a Sym Evo 300i Scooter has no power. It stalls under full throttle and sometimes start jerking. if I switch it off and restart it runs normal for some time.
Hi, Jurie and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Old dead or bad fuel.
12. Fuel tank vent system plugged or carburetor vent line closed off.
13. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
14. Carburetor controls misadjusted.
15. Damaged carburetor.
16. Incorrect valve timing.
17. Weak or broken valve springs.
18. Damaged intake or exhaust valve.
19. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
New Taotao ATM50 A1 Bogs Down Under Throttle Scooter Doc Forum
No power on full throttle main jet carburetor problem fixed
https://scootergrisen.dk/scooterhjemmeside/download/sym_gts_servicemanual.pdf
Oct 05, 2016 | Sym Motorcycles
Taotao 150cc. Three or four hours into a ride, when I pushed the throttle why did it just want to die?
Hi, Alesha and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in the fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Absolutely Scooters Free Scooter Service Downloads
Home TAOTAO USA INC
TaoTao 150cc Scooter Owners Manual
Dec 27, 2015 | Motorcycles
How do I change the rear turn signal bulbs on a TaoTao 50CC @
Hi, Kennie for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your TaoTao, despair not, for a mere zero $0 you can download another one.
How to change turn signal bulb in Yamaha Vino 50cc Scooter XC50
taotao 50 ATM 01 How do you get to rear turns signals 49ccScoot com...
TaoTao Scooters Mopeds Parts
Oct 09, 2014 | Motorcycles
Taotao atm 50 wont stay running. Intake problem?
Hi Jason, for more information about your question please visit the website below. Good luck and have a nice day.
TaoTao 50cc Scooter Owners Manual
Sep 30, 2013 | Motorcycles
My taotao scooter is hard to start either kick or electric. also when i do get it started i have to keep the throttle on so I can keep it going. but when i let go of the throttle it stalls. i have checked...
Hi, Anonymous and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
10. Choke valve inoperative.
11. Engine lubricant to heavy (winter operation).
12. Ignition is not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
https://www.reddit.com/r/scooters/comments/396vz5/taotao_50cc_moped_not_starting_model_number
Scooter Troubleshooting Scooter won start All about Scooters
https://taotaopartsdirect.myshopify.com/collections/quantum-150
TAOTAO QUANTUM 150 Owner Manual
Oct 04, 2017 | Motorcycles
50cc taotao scooter the carb is runs then fills with gas untill it stalls out dont get much off the searchs i have made dont no if it is the carb our choke broke down carb and looks clean no clogs or
My 2012 Taotao 49cc scooter was spitting and sputtering then just died one day. I brought to a small engine repair person and come to find out, the hoses that came off the carb had cracks in them. Changed the hoses and the problem went away. Hope this helps.. I have since replaced the cheap hoses with new ones from the auto parts store and never had the problem again.
Oct 21, 2012 | Star 50cc scooter for kid
There a hose coming from the carb and i dont see where to conect it at. and it leaks gas if u start it. the hose is labled as the number 5 loacation.
Hi, Jadkinsll it may be a vent or overflow hose that is not supposed to be connected to anything just hangs straight down past the frame for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Fuel and Vac Line Tutorial
KLR650 mod carb vent tutorial
benelli velvet service manual pdf 1 Search Document com
http://www.benelli-scooters.de/pdf/BA_Benelli_Velvet125.pdf
May 15, 2011 | 2008 Benelli Velvet 125
49.5cc JCL gas scooter will not start and SHUT OFF WHILE DRIVING 40 mPH!
Hello my name is Tony Tarell im the sales manager at JCL International. Anyone that is having a problem with JCL Scooters please give me a call and i will help you with any problems you have. 972-243-8668 EXT 103 or you can email me at tony.tarell@jclusa.com
Sep 24, 2008 | Sport & Outdoor - Others
Health & Beauty Logo
460 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
