Question about Rheem RTG20220AB Tankless Service Clean Brass Valve Kit with Relief Valve
Flow aide vs. clr for cleaning tankless water heaters
gary1121
  • 332 Answers
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Posted on May 29, 2009
  • 244 Answers
SOURCE: Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Posted on Nov 01, 2009
1stBSP
  • 52 Answers
SOURCE: which circulating pumps works on tankless water heaters
Laing UCT-909-TANKLESS UltraCirc Tankless Water Recirculating Pump
This is designed to maintain the proper flow to fire the heater. Please be sure the pressure in the house is at least 5 psi over the minimum required for your unit.
Posted on Apr 05, 2010
  • 68 Answers
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Posted on Jul 31, 2010
  • 68 Answers
SOURCE: Rheem tankless rtg 74pvn - heater hot water shuts
This is something you will have to contact rheem about due to the fact you don't have a fault code
Posted on Aug 12, 2010
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
I am geting a P1 error code
P1 error code is not enough water flow to operate the unit: increase water flow to unit.
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
Error codes are considered start-point for troubleshooting.
Page 18 of maintenance manual shows how to clean water filter monthly.
Other causes can include faulty sensor, clogged in-line filter, clogged water softener, sediment in pipe, sediment at elbow, bad check valve, water leak, etc.
Take a moment and rate answer:
Sep 11, 2011 | Rheem Tankless Hot Water Heater...
I have an AE125 - had it for a couple of years at the cottage. We got the water hooked up this spring and all was fine. Last weekend, the unit stopped working. I flipped the breakers a couple of times...
Can tankless electric water heater be repaired? Sure.
Is it worth the expense if problem is going to happen again? I can't answer, but can offer resources.
New tank-type electric water heater costs $207 and new tank-type gas costs $320 at local box store.
You can install new tank-type electric yourself in a couple hours. DIY repair on tankless is not easy since parts are not at local box store, and what part do you need, and tankless parts can easily cost more than new tank-type water heater.
Open following link for Bosch troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
GENERALLY, Tankless require .4 gpm (gallons per minute) water flow to activate heating cycle, and then require .25 gmp flow to keep heating cycle going.
For example .4 gallon per minute means faucet can fill 1 gallon container in 2-1/2 minutes
Some tankless units require more water flow, for example .75 gpm
Tankless water heaters have flow sensor that tells computer chip when enough water is flowing to activate heating cycle.
If the sensor is clogged, or if water filter inside tankless unit become clogged with dirt or sediment from hard water, then the unit does not signal enough water flow and will not activate.
Home filtration system and water softener can also slow the flow of water.
Low water pressure and crossover problem on single-handled faucet and crossover on recirculation system check valve and high thermostat setting can also cause heat cycle to not activate.
Tankless cannot be exposed to water with more than 11 grains hardness or parts inside tankless will coat with sediment and not work. Within 2 years the unit will not work, with diminished efficiency from the beginning.
http://waterheatertimer.org/Battelle_Final_Report.pdf
If water is hard, and you cannot soften the water, or if water is dirty and cannot be cleaned, then the best recommendation is to use tank-type heater instead of tankless.
All costs are energy. For average home: Tankless electric is NOT cheaper to operate than tank-type electric. Tankless gas saves $1-8 per month. However, cost of unit and installation, cost of potential repairs and cost of parts, difficulty of DIY repairs, required yearly-monthly maintenance, etc outweigh expected savings.
http://www.pmengineer.com/Articles/Cover_Story/8cf9e86f7c298010VgnVCM100000f932a8c0____
Upvote the help.
May 31, 2011 | Bosch AE125 PowerStar 4 GPM Indoor...
Have a p1 flashing on the remote control and no hot water. I have tried shutting the water and power off and still a p1 flashing on the control unit.
P1 is reportedly defective check valve that can cause water flow to decrease, and tankless not heat water smoothly. But can also be other causes, or combination of causes. Call service technician, contact Rheem, or replace check valve and see if problem solves. Then add a comment with solution so others can benefit from your experience.
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Also take advantage of fixya expert assistance live.
Mar 13, 2011 | Rheem Water Heaters
Noritz Tankless error code 16
The trick with these hot water heaters is to keep the filter screen clean and flush the system with CLR periodically. Code 11 is ignition error. Is your gas valve turned on?
Oct 17, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
I get a P1 error code on my Paloma tankless water heater. It blinks between the P1 and the tempature setting
Water inlet temperature to the heater is the same as preset on the controller.
I had this happen to me becouse I have a solar tank with temp of
135 farenheit.
Once I bypassed the sollar tank..no problem
Sep 24, 2009 | Rheem EcoSense by 7.4 GPM Tankless Water...
Sediment in lines -Bosch Tankless Water heater
I would recommend a simple sediment filter housing be installed on the main water line coming into the house. Material cost about $100. Have a plumber install a bypass loop so you can just shut off 2 valves when you need to change it. I always install one with any tankless heater as cheap insurance against such a problem. As far as adding something to clean the lines I would refer to the manufacturer's instructions and use only what they recommend in order to preserve your warranty. For a solar water heater I prefer Velux.
Please rate if this helps-
Mar 28, 2009 | Bosch & Tankless LP Hot Water Heater
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Rheem RTG20220AB Tankless Service Clean Brass Valve Kit with Relief Valve Logo
229 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
