Question about Whirlpool Inglis IP4400 Washer
Bowl off track
My washer seems as though it is off track. When it spins fast, the bowl moves around alot and makes alot of noise. What do you think is the problem?
  • 240 Answers
Spring missing or skid plate out of place. if the basket has excess movement separate of the tub or agitator then the hub nut is loose or tub rusted out.
Posted on Apr 28, 2009
My bowl spins so fast that the ingredients flu out of the bowl
The bowl is not supposed to spin, it locks into the base of the pedestal. Engage the lugs and turn it one way to lock it up.
Mar 30, 2014 | KitchenAid Classic Stand Mixer
WL70T60D - Loud banging noise during rinse phase
I think something (mechanical) is not in the right position so the bowl is touching its surrounding parts. It is better to get somebody or yourself to open it and fix the losen or deformed parts.
Feb 20, 2014 | Fisher and Paykel Washing Machines
Loud sound during spin cycle noise
you could put some sponge stuff glued to the roof of the machine to dampen the smacking of the bowl on the top. you could also glue some sponge to the top of the ring around the bowl for the same effect. it seems like the springs are too low grade for the washer. I have never seen one of these machines before, but I know washers in general.
Sep 19, 2013 | Haier HLP21N Washer
My fisher and paykel eco washer spins weirdly and makes lots of noises
If the user is complaining about noise, it may be in a number of different areas. Is the noise during
spin? Is it a banging sound? This would typically be the drain hose, inlet hoses, mains lead or
harness. If it is an out of balance noise, check that the machine is level and stable. Check the
bias spring and balance rings. Remove the inner bowl and check that its weight is within
specification (Refer Section 1.12).
If it is a 'clunk' that occurs up to 3 times per cycle, this would be a bowl check and is completely
normal. It occurs when SmartDrive is draining and 3/4 empty. This is a 'feature' and a noise that
cannot be reduced.
Other things to check are:
• Is SmartDrive level and on all four feet equally.
• Check the mains lead, inlet hoses and drain hose outside the wrapper, behind SmartDrive.
• Check the harness and drain hose inside is not banging on the wrapper during spin.
• Check the bias spring is fitted correctly.
• Check the 2 balance rings in the inner bowl contain water. Check the bowl weight.
• Check for noisy suspension rods.
Apr 04, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Hi my machine is making a crunching noise what could it be?
It could be a foreign object stuck between the drums. Have a very close look around the spin bowl for signs of a bra wire or similar sticking through one of the holes in the tub. There may be a coin or something else stuck where you cant see it and it will require removal of the spin bowl ( A very big job) If the machine is older ( 6 to 10 years old) the bearings may have failed. Grab the spin bowl through the door opening and see if the drum moves up and down. If it does, its a sign that the bearings have failed and /or the main shaft has broken or worn out... Another big job. It may be cheaper to replace the machine if either of these faults have occurred.
Jul 31, 2011 | Electrolux EW1000i Front Load Washer
A loud banging noise while spin drieing.
when the bowl is empty check that the drum is not loose that is the inner and outer concentric drums bist be solid in relation to each other. the whole unit will move around though If the inner is loose then you cant use the washer until the bearings and spider are renewed cheers
Jan 23, 2011 | Whirlpool GHW9200L Front Load Washer
Water has been leaking out of the bottom of my washer, and it has been making a horrible grinding sound. It finally stopped spinning last night, though it makes noises and tries to run.
Hi just read your posting.Now when is the machine noisy?Is it when the machine pumps out the water or when the bowl spins.Sorry to ask you this but please be accurate when you reply to this question.The reason being is that if it is noisy when it pumps the water it could be your pump but if it is noisy when the bowl turns for the spin then the problem will be your bearings and seals.Select a spin cycle and push start,is it noisy as soon as you push the start button?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
If my washer machien makes a noise like boom boom and moveing what do i do get a part to fix it
The correct answer will depend on exactly what your washer is doing when the Boom boom noise is heard.
I will take a guess that it is on the 'spin' cycle or 'rinse' cycle - while the bowl is spinning. The boom sound is your wash bowl (drum) hitting the rubber bumpers located on 3 metal beam like parts.
The cause is either a bad balance in the load (lots of jeans bunched up on one side of the bowl throws is out of balance and it hits the sides. Or- one of the 3 springs that hold the bowl in the center of the machine cabinet is off its fastener. You can look under the machine (lay it on its face - on a towel or rug), with no water or clothes in it..... and check to be sure all the springs and fasteners are in place.
If one is broken, pull it out and take it to an appliance parts place in your area.... and get a new one. Just install the replacement part like the other 2 assembles inside the cabinet.
Let us know this does it for you.... -Jim
Oct 22, 2009 | Kenmore 22622 Top Load Washer
Even though I pour the ingredients into the ice cream maker while the motor is on and the bowl is turning, it seems to freeze too fast and then the inner piece won't turn. When the inner piece stops...
You have exactly the opposite problem of most users - for you, I would reccomend taking the freezer bowl out of the freezer a bit earlier than usual, slightly warming the initial ice cream ingredients, or raising the temperature of your freezer. To an extent, you will always get that rim directly on the sides of the freezer bowl, but my rim never extends so far out that it stops either of my two Cuisinart ice cream makers (or their paddles/bowls) from spinning.
Aug 07, 2009 | Cuisinart Ice Cream Makers
My Hotpoint washer dryer WD865 moves around the room making loud noises when on a fast spin? The internal drum seems more loose than normal?
I had the same problem. You can open the top lid (2 screws at the back and then lift) The weight which is on top is secured by three bolts, all three of them were loose so weight was going from one side to another which made a terrible noise. Tightened the bolts and noise was gone!
Dryer still not working though.....
Aug 06, 2008 | Washing Machines
Whirlpool Inglis IP4400 Washer Logo
261 people viewed this question
Dan Webster
Dan Webster
Sal De
