What is wrong with my audio plug?
How to fix an audio jack on a laptop? / What's your diagnosis
If somebody could help me out...I'm pretty sure I blew something up when I plugged the output of a guitar amplifier to the headphone jack of the laptop because since then, when something is plugged in that jack, (speakers or headphones) nothing comes out. When nothing is plugged in, the sound correctly comes out of the two internal laptop speakers. Does anybody understand what happened
  • owen kardon Jan 19, 2009
    Thanks a lot pgh_pa_guy for your help. So you are saying that I need to purchase a whole new system mother board simply because of this problem? How is it that the internal speakers work then? thx
  • owen kardon Jan 27, 2009
    pgh_pa_guy,
    thanks a lot for the external USB sound card that was a great idea. Surely a lot cheaper than trying to get my motherboard fixed.
    Does that "small amplifier" that i have burnt have a name?
    President:
  • 2,992 Answers
Yep, you blew it up, all right.
The headphone jack in the laptop is a low-level OUTPUT which goes TO a set of headphones or the INPUT of an amplifier. You went the wrong way and fed a high-level signal (the guitar amplifier OUTPUT) INTO the laptop.
The electronics inside the laptop are not made to deal with the high level you fed in, so it's been damaged. Ever blow out a set of speakers with too high a volume? That's basically what has happened here.
To fix the problem and get your sound back would require a new system board.
Posted on Jan 19, 2009
  • Jan 20, 2009
    The internal speakers and headphone output are driven by a small amplifier which is part of the main board's audio circuitry, and that is what you've toasted. The part of the audio circuit (called a codec) which converts digital audio data (from programs, a CD you might be playing, etc.) into the analog signal to the speakers is probably still functional, but there's now no way to get that signal out. Hope this clears it up a little for you.
    Actually, I just had a thought. You can purchase an external USB sound card which would allow you to get sound. It would mean an extra piece you'd need to plug in, but you'd be salvaging the system. I don't know the specific model, but some friends got one by Creative, and I think it's USB powered (meaning no extra adapter).
  • Jan 27, 2009
    Actually I'm embarrassed to say that after all I said, I found I'd misread your problem even though I'd looked it over several times before posting a solution. I thought you were saying nothing came out at all. But after re-re-re-reading it I saw it worked with the internal speakers but not when something was plugged in. (Another senior moment, I think.) These jacks are usually wired like the headphone jacks on boomboxes: when you plug headphones in, the internal circuit to the speakers is broken so they are shut off. The signal that goes to the speaker amplifier (and that's what it's called - it's just a small audio amp circuit designed to run the speakers) is sent out the jack only.
    But not all laptops are made the same, so yours may have a second audio signal path from the main board to the headphone jack, and the parts driving that path were damaged by the amplified signal you fed into it. So the internal speakers continue to work, but there's no signal now available from the headphone jack.
    It's possible you might be able to see the damaged parts if you open the computer and look at the main board. Sometimes when a part gets hit with a much larger signal than it was meant to take it literally blows up and you can see cracks, burned spots, or such. But repairing the board is usually beyond most servicers (special tools and techniques are needed).
    Sorry for any confusion I've caused you. But if you want to hook external speakers or another output cable to this laptop, the USB device is still the best idea.
I can't seed to get my speakers to work. I have UBL pro speakers.
1. Check the Audio icon on the task bar if muted. If yes Unmute Go to start > control panel > sound. and make sure that nothing is muted.
2. Sound Diagnosis refer this photo
3. Re install the audio drivers. LINK
4. If steps 1-3 don't work, then take your speaker to your friend's computer and see if it works there? if yes then something is wrong in your computer system, if no, then something is wrong in those devices.
Refer to this image below. From your speaker the 3.5mm jack should be plugged at back of I/O ports LINE OUT.
Thank you for posting hope this helps..
Jul 06, 2011 | Computers & Internet
My laptop is not turning on.When i plug in the charger not one thing happens whats wrong?
It sounds as though your DC Jack (where the charger plugs in) has broken off of the motherboard. I would suggest sending it to a computer repair shop for a proper diagnosis as a DC Jack can be very expensive to fix.
The jack is general soldered directly to the motherboard (see picture). As such the repair can put the entire computer at risk if done incorrectly.
Mar 03, 2011 | Maxdata M-Book 1000T Notebook
Fuse blew out on my american audio after my girlfriend tripped on the chords, how do i repair it . is there a fuse or a reset button thank you
You are saying the fuse blew out and then asking if there is a fuse??? That makes no sense...
Tripping on cords could do certain things but NOT likely to blow a fuse.
Tripping on cords OFTEN breaks the plugs on the cords or the jacks in the equipment. The power input jacks from those wall transformer power supplies seem to be very vulnerable to this. They often disintegrate OR break loose from the solder on the circuit boards rendering the unit inoperable.
In future, loop the cords through handles so they don't yank the jacks if somebody yanks the cord.
Dec 26, 2010 | American Audio CK 800 MP3 CD PLAYERS SOUND...
No audio output i tried restoring and rebooting but nothing. Macbook Air.
Usually a problem with your audio jack. The jack detects an optical plug and switches to optical audio. Clean it with a compressed air can. Otherwise The apple store will probably help you. If not there are third party places that will find out what's wrong. If you want to do it yourself, the good news is, it'snot too hard to open it. Here is an Macbook Repair Guide that shows how to open an Macbook. Just open it and let it try, clean off any corrosion you can find. If you want somebody else to do it for you go to iPad Repair NYC.
May 06, 2010 | Apple MacBook Air
When audio jack is plugged into mac a high pitch whine is heard across speaker system
I'm thinking it could be a feedback loop. Maybe for some reason when you plug in the headphones it does not turn off the speakers but ramps up the mircophone. Clean you your jack to make sure it detects the headphone plug right and turns off the speakers. If that doesn't help you may have a logic board issue. If you want to replace it yourself, Here is an Macbook Repair Guide that shows how to open a Macbook. If you want somebody else to do it for you go to Macbook Repair.
Jan 07, 2010 | Apple MacBook Air
Is my sound card fried?
hmm ,,,r u not geting sound ,,well try download the sound drivers ,,you can download the sound drivers from this website sound drivers ---> http://www.softwarepatch.com/utilities/ac97.html and http://www.softwarepatch.com/utilities/ac97.html
Jan 13, 2009 | Computers & Internet
Stereo Speaker troubleshooting
It sounds like the audio jack itself has internal damage. Depending on how it is mounted on your laptop case, or possibly on an internal circuit board inside the laptop; it might be possible to repair the jack or replace with a new 1/8" audio jack. Some soldering skill may be required after disassembling the laptop and getting access to the jack.
Jan 12, 2009 | Computers & Internet
External speakers won't work when plugged in to computer
Make sure the balance control in your VOLUME CONTROL icon in windows tray (by the clock) is centered....
There are sliders for each output/input and a balance control for each of these. uncentred they can switch off one channel.
Jan 08, 2009 | Computers & Internet
Audio problems
Try to go to the device manager or make sure that you see the volume icon on your system tray if you see it but you can't click then there might be a problem on the driver. if not then you need to ask somebody to check if your motherboard is broken.
Oct 30, 2008 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
506 people viewed this question
David Payne
David Payne
