Question about Xerox Office Equipment & Supplies
Xerox Colorqube 9301 error code 093-551
Error code 093-551
SOURCE: xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Posted on Feb 03, 2011
checkitright
  • 1362 Answers
SOURCE: xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Posted on Aug 11, 2008
checkitright
  • 1362 Answers
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Posted on Sep 08, 2008
SOURCE: Xerox Doc12 10-386 error code
10-386 Error
Posted on Dec 01, 2008
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
What causes error code 091-720 on a xerox colorqube 8900x printer?
That error signifies a printhead tilt fault. You need to replace the process drive camshaft kit, part number 8900-Z1.
http://www.iteminconline.com/8900-z1_8900-z1-xerox-8900-process-drive-camshaft-kit.htm
Feb 29, 2016 | Xerox ColorQube 8900X Multifunction Color...
What does error code 093-547 on a Xerox ColorQube 9301 mean?
Interesting. Recommend reading and trying the software from Microsoft. http://www.saetechnologies.com/colorqube-error-code-093-547/
Jul 17, 2014 | Xerox Office Equipment & Supplies
Xerox error codes
error code 377.123.02 for Xerox 6700
Jan 12, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Getting error code 093-516
I looked at the Xerox 8900 support page: http://www.support.xerox.com/support/colorqube-8900/support/enus.html
The answer I found for Error Code 093-516 was problems with Yellow Ink Stick. Our printer had been switched of for quite some time which probably caused the ink stick/sticks to get stuck (or something). I opened the ink bay and pushed slightly on all the sticks to make sure they were "all the way in", added some more ink behind them and it started to work again.
I had to do a few cleaning jobs for smudges and now it's fully operational.
Jan 03, 2014 | Xerox ColorQube 8900X Solid Ink...
Error code 099-405
The error code refers to a Hardware "Pest" Fault (RAP Group:Power, Head Thermistors Name:Power, Head Thermistors). You should contact Xerox Support by phoning them directly. You'll find the numbers relevant for your Country here >> http://www.xerox.com/about-xerox/contact-us/enus.html
Nov 30, 2013 | Xerox ColorQube 9303 Printer
Xerox error code 093-559
On the ColorQube 9201 and 9300, this error says "Head 3 cyan reservoir did not fill within the correct time." This a difficult machine to service so you shouldn't start without full documentation and experience.
This code may require one of a dozen parts, most of which are expensive and challenging to install.
Good luck ...Whit at www.iteminconline.com
Sep 03, 2013 | Xerox ColorQube 9201 9202 9203 Cleaning...
Xerox ColorQube 9201 error code 093-559
The ColorQube is a big $20K machine that is rather difficult to repair. Hiring a professional is the best practice. Even so, being informed will assist your discussions with the technician.
This error tells us that a Cyan reservoir isn't filling up. There are many suspects, probably Purge Line, Ink Reservoir, or Printhead. If you want to repair it on your own, you will need a service manual, and tech support.
Whit
Item, Inc.
What does error code 91,721.00:1039 on Xerox ColorQube 8570 mean
The error is a printhead tilt fault. It's unable to tilt on the axis, caused by a fault camshaft and process motor. The part you need to fix it is 8570-Z1.
http://www.iteminconline.com/8570-z1_8570-z1-xerox-colorqube-8570-8580-8700-process-drive-camshaft-kit-includes-process-drive-motor-drum-maintenance-camshaft-transfix-camshaft.htm
Aug 13, 2012 | Xerox Office Equipment & Supplies
371 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
