Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Furnace blower not working how it should
The furnace itself is working properly it just when it reaches the right temp in the house the blower will not shut down it keeps running til it starts blowing cold air again i have to manually shut the switch off and turn it back on and everything repeats itself again...this is a model AGU10016A COLEMAN EVCON FURNACE WITH A LUX DMH110 NON PROGRAMMABLE THERMOSTAT
  • collections Jan 31, 2009
    i bought a honeywell thermostat to replace the lux and it still does the same thing ,, i also replaced the limit switch and roll out switch and changed the filter still the same problem what else could it be with everything else running properly colud it be the circuit board i am totally lost..........
  • akgbob Mar 03, 2009
    Same exact problem. Would love to hear if anyone has an answer.
    Lux thermostat on newer heater. Turns on and heats up just fine, but once the temp is reached the fan stays on and starts pumping cold air (continuously until I turn it off myself).
    Thanks,
    adam
    Novelist:
  • 88 Answers
First off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Posted on Jan 20, 2009
    Scholar:
    New Friend:
  • 70 Answers
If you could give me a little more information on what is going on i can give you a few things to check. How long does furnace run? Does furnace turn on and off every couple of minutes? How old is furnace? Is this furnace old or new? Have you checked Filter? has furnace been cleaned? Have you replaced the thermostat? do you have to turn furnace off and then back on before it will work again? I think from the information i can see is the thermostat is not turning off when it reaches temperature. if that is the case i would change out thermostat. I would install a digital instead of a thermostat with a mercury bulb. The digital will be an accurate temperature .
Furnace blower fan stays on
Gotta have some info..............is It a gas furnace?What brand?Model?
Fan switches do get stuck ON. Is it blowing ALL the time,cool air? don-ohio
Dec 30, 2016 | Heating & Cooling
My Payne furnace is NOT producing the desired heat anymore. Any ideas?
Hello, it could be shutting down on it's high limit switch due to a dirty air filter, dirty blower wheel, weak blower motor. Usually this would cause the furnace to shut down before it reaches the desired temp.
Dec 30, 2011 | Heating & Cooling
My goodman furnacs says my limit switch is bad blower works but does not ignite .....? its modle gmt070-3 and where is it located
There are several limit switches in the unit there in various places in burner compartment. One on blower housing . One thing that I would try is replaceing your filter and turn the power off to the furnace and try starting the system after power is D/C for 5 minutes.
May 02, 2011 | Goodman GMS90703BXA Heater
I have a Ruud Silhouette 2 The problrm is it will start up the burners come on they go off about 10 seconds later, also when the house reaches stat temp the heater will kick in and of at the same...
Hello, this sounds like a flame sensor issue or high limit switch problem. First, turn off power to the Furnace and remove flame sensor, it is a small metal rod on the opposite side of the igniter, use some steel wool to clean it up and reinstall it. If that does not solve the problem then inspect you filter, blower wheel for dust or dirt, also make sure the blower motor is running at the proper speed. I hope this helps.
Mar 21, 2011 | Ruud UBHC Air Conditioner
Furnace blowers continues to run after reaching temp
It actually sounds like you may have answered the question yourself. If the mercury isn't breaking contact, then obviously it's still calling for more heat. This is a common problem with the old mercury thermostats and are usually replaced with digital ones that are way more accurate. The are fairly cheap at Wal-Mart and such, and replacing one is basically all color coded.
Jan 27, 2010 | Electric York / Paragon A-111-20 Heat...
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Furnace not cycling properly
sounds like the flame sensor needs to be replace. You can try cleaning it with steel wool. This will get you by for a little while.
Jan 17, 2009 | Honeywell Electronic Programmable...
Furnace won't stay running
1 FLASH
Furnace fails to operate.
• Integrated control module
diagnostic LED is
flashing ONE (1) flash.
• Furnace lockout due
to an excessive
number of ignition
“retries” (3 total)1.
• Failure to establish flame.
Cause may be no gas to
burners, front cover
pressure switch stuck open,
bad igniter or igniter
alignment, improper orifices,
or coated/oxidized or
improperly connected flame
sensor.
• Loss of flame after establishment.
Cause may be
interrupted gas supply, lazy
burner flames (improper gas
pressure or restriction in flue
and/or combustion air
piping), front cover pressure
switch opening, or improper
induced draft blower
performance.
• Locate and correct gas
interruption.
• Check front cover
pressure switch
operation (hose, wiring,
contact operation).
Correct if necessary.
• Replace or realign
igniter.
• Check flame sense
signal. Sand sensor if
coated and/or oxidized.
• Check flue piping for
blockage, proper
length, elbows, and
termination.
• Verify proper induced
draft blower performance.
Nov 23, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
1,753 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
