Question about Watches
How do you set the time on an automatic Andre Belfort watch, I can set day and date but not the time
  • 17 Answers
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
Posted on Jul 30, 2008
escapement
  • 2334 Answers
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
SOURCE: can't set day and date on cote d' azur watch
Actually I can't solve this. My son bought the same watch on a Carnival Cruise and had the same problem. Upun closer inspection with a magnifying glass, it is obvious that the hands on the day and date dials are fake!! They are just attached in the center to the watch face. The other two push knobs on the watch also do nothing at all. So basically a rip off, but at least it was only $20. At least it keeps time for now. As usual, if it seems to good to be true, it almost always is. Sorry about that, but we are in the same club with you.
Posted on Jul 03, 2009
escapement
  • 2334 Answers
SOURCE: Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Posted on Mar 31, 2010
Testimonial: "Thanks so much. I thought I had tried what you suggested already, but apparently I hadn't. The watch is now set correctly. Thanks again!"
mcdevito75
  • 1970 Answers
SOURCE: How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Posted on Jul 21, 2010
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
The calendar skipped ahead a day and I can't get it back to where it reads the correct date. Can you help?
Pull the stem out to the time set level. Turn the hand around until the date change. Now push the stem back in, pull to date set level and change to current date. Now the watch is at midnight for that current date. Note you can set to current time of day. The Watch will automatically change to correct date for next day at midnight as it should.
Oct 17, 2013 | Michael Kors Watches
How do I set my watch in order for the time and date to change at the proper time?
This depends on the watch. But first you have to ensure that when setting the watch it is set to AM or PM depending on what time of the day it is. Once this is set the date will automatically change when the day comes to an end.
Hope this solution has been helpful?
Mar 11, 2011 | Watches
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
Mar 31, 2010 | Watches
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
Aug 30, 2009 | Invicta Corduba Leather 3809 Watch for...
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
May 03, 2008 | Seiko SLL003 Wrist Watch
Operating instructions for a replica Rolex oyster perpetual cosmograph daytona watch
I need to know if this watch is an automatic or quartz (battery-operated) watch. For either watch, your crown screws in clockwise- which, by the way, is on the right hand side of your watch, and looks like a miniature doorknob. Unscrew it COUNTERCLOCKWISE, then, if your watch has a date on the dial (face of watch), your crown will pull out in two different positions. The first position is for your day/date. Forward will either do the day or date and backwards will do the other. DO NOT SET YOUR WATCH BETWEEN 10 O'CLOCK AND 2 O'CLOCK, because it can ruin your watch. The second position (pull out completely) is for setting the time. Go around until the day and date changes so you're sure that you're on a.m. or p.m. and then set accordingly. Push the stem all the way back in - this is your winding mode if you have an automatic. Wind 50 times before use, or else it won't run correctly. Now, push the stem back in (it's spring-loaded), and turn it counterclockwise to seat the tap, then clockwise until it's completely screwed in.
Apr 22, 2008 | Watches
Watches Logo
433 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
