Question about Kenmore Washing Machines
Control panel Kenmore heavy duty top model C97841160
Owner manual with photo of the control panel open
tzweeb
  • 318 Answers
SOURCE: kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Posted on Jan 31, 2009
  • 17 Answers
SOURCE: Model 110 top loading washer will not spin
check belt
Posted on Apr 10, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore Washer will not drain
Hi, When the the water is suppose to be draingin, do you hear the motor humming at all?
It could be that something is plugging the pump. You can tip the washer toward the wall and look underneath. The pump is right behind the front panel and easy to get to. You can try lowering the drain hose into a bucket and see if the water will release.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on Jul 09, 2009
SOURCE: Washing machinge just stopped during agitation cycle
iI have a kenmore 60 series washer model 110.81664110. It will not spin. After taking the bottom panel off I noticed what looks to be a small belt. The washer looks to be direct drive, the coupling is not broken. Can you please tell me what this "belt" is and how to change it? And could this be the problem causing it not to spin?
Thanks very much for any help I can get.
Posted on Jul 17, 2009
mgprice
  • 744 Answers
SOURCE: kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Oct 14, 2009
I have a Kenmore heavy duty 80 series washing machine. Model 110.26852503. At the end of the cycle I lifted the lid and it was still full of water. The control knob feels stripped. The only function that...
On a Kenmore, the control panel probably rotates up (after screws are removed ) to expose the knob. Go to www.repairclinic.com and enter 110.26852503.With luck, you will be presented with a list of common replacement parts and may be able to vie a generic Kenmore video showing disassembly.
Aug 28, 2017 | Kenmore 24032\24036 Top Load Washer
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
How do you get the top of the cabinet off of a Sears heavy duty washer series 80, model #11092283800? It vibrates excessively w/o a load.
should be 2 screws in the control panel ,some panels you need to remove the end caps to remove them,then just flip the control panel back it has plastic hinges so be careful,then you unplug the lid switch,pop off the 2 gold clips holding the back panel to the housing.then just reach inside the lid tilt slightly towards you and lift off the frame.
Aug 01, 2010 | Kenmore 23822 Top Load Washer
Want a owners manual for a stacable Kenmore heavy duty Mod 110.88732796 -
Go to managemylife.com and type your model number under the "Manuals" link. Your owner's manual is available in .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Apr 02, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washers, heavy duty 80 series, no spin
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Speed Control only works in Heavy Duty
sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Turn off buzzer
some models have a buzzer in control panel which can be unpluged wire sealed off ather built into time and can not be turned offf good luck
Mar 04, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 70 Series heavy duty washing machine
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Mar 01, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
