Where can I buy JVC SP-FSY1?
We have lost the speakers for a JVC Compact Component System CA-FSY1. Where can we buy them (SP-FSY1) or find out what other speakers we might use?
5 Suggested Answers
  • 909 Answers
SOURCE: A power surge zapped my JVC MX-D661T compact
Open it up and check for internal fuses, if any in there, test with a wire, bulb and battery. The values (voltage and amperage) will be on the fuses or next to the fuse holders. Also look for any obvious burnt components like diodes( small bleck tripods) and capacitors(coloured "tubes" with a wire at each end) and resisters(like capacitors but with coloured stripes on). Obviously it will be cost dependent.
And most important UNPLUG BEFORE OPENING and be cautious as capacitors may be small but they can hold a very high voltage for a long time.
Posted on Aug 17, 2009
freetek
  • 5568 Answers
SOURCE: Hello, I posted some time with you and I would
This is a website that offers two levels of service help; it does not sell anything directly but only has links to those who do sell products.
Posted on Jan 05, 2010
dunnbiker
  • 8546 Answers
SOURCE: My jvc compact component system
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 21, 2011
AJIN G
  • 6694 Answers
SOURCE: JVC /MX-D761T/ compact component system> The
hi,
Is there is power in your system. is there is any power indication.if not then you have to check the Powre transformer, its fuse, and the small standby transformer near the power transformer. If the stanby transformer is faulty then there will no power indication in your system.
If there is power and the cd is not reading then, You have to check the laser pickup unit inside your system. First of all purchase a laser cleaning cd and insert the same in to your system. If will clean the laser pickup unit to some extent. if then also it is not reading any cd then the laser pickup is faulty. As it has a changer mechanisum it will be difficult to you to replace the lase pickup unit.Because you have to remove so many parts from the mechanisum to reach to the laser pickup unit. If so try to consult some one experienced in it.
ok
Posted on Jul 30, 2011
JVC MX-C5 Compact Component System has a broken mini gear
If you can't get it to work, I would love to purchase the remote as I have lost mine.
Dec 04, 2013 | Harman Kardon JVC UXG50 Micro Stereo...
Hi, I have JVC CA FSY! and it has static noise on speakers but its ok on headphone. How can I solve this problem?
http://books.jvc.com/booklist.asp?Model=fsy1
Choose your submodel.
So the good news is that the amp isn't implicated but an electrical conductor somewhere in the path may be flaky.
Headphone insertion mechanically disconnects output to the speakers. Hence, headphone removal relies on spring-loaded contacts to restore the output to the speakers. Perhaps there is oxidation on the normally-closed contacs. Repeated headphone insertion/removal MAY help wear it off.
Also try swapping the speakers (wire and all) to see if the static follows or stays with the amp channel.
Jul 12, 2011 | JVC FS-Y1 Theater System
Hello, I posted some time with you and I would like to buy from this compact component system CA-HXD7, but without speaker
Jan 04, 2010 | JVC HX-D7 Shelf System
Need to set clock on jvc compact component stereo amp
How do I set the clock on my jvc compact disc audio system. model # KD-G110
Oct 21, 2009 | JVC MXKC4 360-Watt Compact Component Audio...
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
Open the speaker unit
You probably need to remove the speaker itself, the cabnet is probably sealed.
Hope that fixed Ya...
Geno
Mar 29, 2008 | Audio Players & Recorders
Boombox on standby
i have a jvc compact component system ca-hxd7 an when you trun it on it pop real loud an then read PROTECT then goes off what can we do
Dec 03, 2006 | JVC RC-BX530 Cassette/CD Boombox
21 people viewed this question
 Grubhead
Grubhead
