Question about iRiver PMC-120 Digital Media Player
My laptop does the "found new hardware, mtp device" popup, but doesn't recognize it as iRiver
My laptop recognized the device 4 days ago and I was able to remove all but a few of the MP3s stored on it, as well as half of the movies. Problem is, I removed these files using Windows Explorer (the device acting as a hard drive) then tried to sync with WMP11. No luck - no files were transferred. Attempted to transfer for 2 hours, gave up and the next day asked a tech friend for help. He gave up after not finding drivers - wouldn't even try it on his 2nd or third computers, each with a different config! (Sorry, ticked about that) Now when I connect it to my laptop I get "found new hardware mtp device" but it doesn't find the iriver. I've taken out the battery, hit the reset button a couple times, no luck. Also tried a different USB cable with a connection that fit the player. Tried running it as the only USB device installed. None of the above worked. Any suggestions or should I look for a new Multimedia player?
  • venussuz Jul 17, 2007
    Unfortunately, it came without a cd, as I got it from Woot. So no help there. As for WMP 10, my desktop PC has WMP and IE6 - holding off on updating that one, but it doesn't recognize the IRiver either, nor would a the tech friend's computer, which was running WMP 10. So that isn't a help.
    Novelist:
    Scholar:
  • 84 Answers
Hi venussuz...The driver for the 100 Series can be downloaded by clicking on the Following URL....good luck my friend http://www.iriver.com/support/down_ok.asp?idx=3140
Posted on Aug 03, 2007
  • 944 Answers
Here's the link for the user manual if you need it; http://www.iriveramerica.com/download/pmc/PMC-100.pdf check page 137 of the pdf and try the restore to original settings. do you have the setup cd? - it has troubleshooting for the unit, which is not available on the website there are no drivers available, it uses windows media player as a driver, but the manual and the support site; http://www.iriveramerica.com/support/multi/pmc100_faq.aspx both claim that you need windows media player 10, not 11 to synchronise. you can download it from this link; http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx or install it from the setup cd just uninstall wmp11 first. many of this type of unit and mp3 players etc have problems with wmp 11, hopefully reverting to 10 will allow you to sync Hope this helps :)
Posted on Jun 27, 2007
SOURCE:
Iriver T30 is not recognized by my windows xp
It should only need a new driver installing. If the Iriver came with a disc of drivers you can use that or search on-line for a driver for it.
If you can't find one remove it completely from the system and then reinstall it.
Sep 21, 2017 | iRiver T30 MP3 Player
I can not delete unreadable/corrupt music(MP3) files
When your iriver H10 has corrupt files you may want to solve the issue by formatting the player's hard drive.
This is how I did it with my H10 5GB (so called 'MTP device' thats recognized by Windows as a portable device i.e. "Windows Portable devices".
To do so follow 2 steps: step 1: Format the hard drive of your H10. step 2: Re-install the player's firmware.
step 1: Format the hard drive of your H10: --------- 1. Make sure your H10 is turned off and disconnected from the computer. 2. Take out the battery, wait a second, and put the battery back in. 3. Turn on the hold switch (so that you don't accidentally turn the H10 on all the way). 4. Plug the H10 into your computer. 5. Turn on the H10 while holding the "O" button. On your H10 screen You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button. 6. On your computer, start Windows Explorer, navigate to the drive, right click and select 'Format'.
step 2: Re-install the player's firmware. --------- 1. Download and install iriver Firmware Updater v2.4.0.0. I found a downloadable copy on this website: http://www.opendrivers.com/driver/237145/iriver-firmware-updater-v2.4.0.0-for-mtp-devices-windows-free-download.html 2. Start the newly installed software and follow the Wizard. I clicked the 'USA' button when asked where I bought the device. This should install the MTP firmware. 3. Wait for the software to complete and disconnect your device from the computer. 4. Wait for your device to install the new Firmware.
Oct 01, 2009 | iRiver H10 MP3 Player
IRiver Music Manger not recognizing iRiver player when connected
First make sure you have the right drivers installed, you're hearing the "new device connected" sound when you plug it in, it's listed as recognized under device manager, and the only problem seems to be that iriver music manager isn't recognizing it.
If everything is working except for the music manager, then try holding down the "fast-forward" button at the same time that you connect the cable to the iriver. You probably want to keep iriver music manager loaded, to see if it's recognizing the player while you test this; try attaching/detaching the device several times, while you're holding down fast-forward and while you aren't, to see if that's enough to fix your problem.
I have no idea why it works when it does, it's an ugly kludge, but it seemed to fix the problem for me, and saved me from having to buy an entirely new flash mp3 player to replace this ancient one.
Jan 23, 2009 | iRiver iFP-795 MP3 Player
Ipod isnt detected.
For it to recognize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognized by the computer
---John
Give credit to Randomassist
Dec 01, 2008 | Apple iPod nano
Mp3 not recognized
Unplug mp3 player from computer. Go to Control Panel --> System --> Device Manager --> Uninstall MTP Device. Uninstall all Philips software. Reinstall Philips software from the CD or the Philips website. Replug mp3 player into computer. Good luck!
-Tha Mp3 Doctor
Jul 16, 2008 | Philips GoGear SA178 MP3 Player
USB not recognized
For it to recongnize, maybe try:
2:add hardware
this should make it so your ipod is now recognised by the computer
---John
Jun 11, 2008 | Apple iPod nano
Not recognized by my Win XP SP2 computer
You probably erased some of the players system configuration files in the process of your file removal. You might want to reformat the device by going to my computer and right clicking of reforamt this device. Once completed you might want to unistall the device as well and make a complete fresh install of it by either installing the driver again using the players website download or the cd that came with you player. To unistall the device do the following: 1)Go to start 2)Right click on my computer and select properties. 3)Once there go to the device manager tab. 4)make sure it is connected 5)Find your device and right click and click uninstall. 6)After just restart your system and install the driver again for your player or insert the Cd another alternative would be instead of uninstalling is to check for a device update.
Jun 27, 2007 | iRiver PMC-120 Digital Media Player
Iriver T10 will not allow me to add songs
The updater that I could find directly via iRiver support did not work, but based on one of the other tips, I googled for the Version 2.7.0.0 updater ([MTP] iriver Firmware Updater for MTP devices).
http://www.iriver.com/flash/popup/flash_pop.asp?board=down&code=736
I recommend that you try the "normal" updater from the website (maybe yours is not an MTP version), and if that can't recognize your player, try the updater from the link above.
Note: The updater seemed to hang at 50% for over 5 minutes... I gave up and unplugged it. Then it asked me if I wanted to upgrade the firmware. "OK," I said. It took a few minutes. The screen went blank. I put in a fresh battery. Turned it on. It works. I was able to use Media player 11 to synch some songs to it.
BTW: It did blow away all the songs on the device, even though I chose "update" instead of "recover".
Dec 27, 2006 | iRiver T10 MP3 Player
My iriver T10 is not being detected
That happend to me and i found a solution. First go to my computer and on your left click on VIEW SYSTEM INFORMATION then go to HARDWARE now click in DEVICE MANAGER it should say T10 around there look for T10 or IRIVER T10 and click on it press in UPDATE THIS TIME ONLY or an option you like and click next then click on the RECOMENDED OPTION to install the iriver t10 after you do that a magnifying glass should appear and wait and it would install saying MTP.
If still need help send me a message at [email protected]
Nov 26, 2006 | iRiver T10 MP3 Player
Open Questions:
pmc 120 when i set up a sync list on media player and start to sync it to the pmc, it works sometimes, other times it aborts. it gives me the message "you can now disconnect iriver Portable media centre" when i try to do it again it tell me Windows Media Player encountered a problem while synchronizing the file to the device. For additional assistance, click Web Help. when i go to th web help it explains the problem as You've encountered error message C00D1236 while using Windows Media Player. The following information might help you troubleshoot the issue. Cannot sync the file Windows Media Player encountered a problem while synchronizing the file to the portable device. Because this error can occur for a variety of reasons, there is no single solution. To resolve the problem, try disconnecting and resetting the device. See your device owner's manual for specific instructions on performing this procedure. In some cases, this error can occur if you try to sync a hidden file to a device. To resolve this problem, either remove the file from the sync list or change the file's properties so that the file is not hidden. Also the error details are Technical Details This error might have been triggered by an error in another program or component of Windows. The following information describes the original error. Original Error Code Original Error Message C00D1179Windows Media Player does not detect a portable device. Connect your portable device, and then try again. So im not sure why it keeps aborting. if you can tell me your views on this please do. Other information that may be useful i tried formatting the unit : 1. Through windows media player 2. through explorer the pmc is supposed to be used with windows media player 10. i had wmp 11 originally and it didnt really work too well. i rolled back to 10 and it worked better but still not consistantly. i tried installing wmp11 again and now the Pmc120 will abort after about 3 songs of an album i would have setup to sync. thanks for your help. Gavan Doran. Ireland.
Oct 16, 2007 | iRiver PMC-120 Digital Media Player
iRiver PMC-120 Digital Media Player Logo
201 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
