Question about Pride Health & Beauty
Pride legion SC3000 Scooter speep ajuster not working correctly
Speed ajuster works intermitly
  • Pride Master
  • 9,742 Answers
The speed pot may need to be replaced. They do wear out after time.
Posted on Feb 24, 2015
  • 32 Answers
SOURCE: my pride go go elite scooter dies
it is either a bad throttle pot, or the set screw that holds the thumb forward/reverse paddle is loose causing the speed to slip, allen wrench to tighten if setscrew is problem
Posted on Apr 20, 2009
my-mobility
  • 9 Answers
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… info@mymobility.co.nz
Posted on Jun 22, 2009
  • 175 Answers
SOURCE: my pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
Posted on Aug 28, 2009
gewiz
  • 1263 Answers
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Posted on Oct 01, 2009
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
I have a pride celebrity mobility scooter model no s4625701012030 i need speedcontrol leed
It's more likely to be the speed control potentiometer (pot) that is giving you trouble, they quite often go wrong. Replacements are easily found on eBay and are not expensive - but be sure to buy the correct one... and carefully note the cables and terminals used BEFORE you remove the old one.
Jun 13, 2014 | Pride Health & Beauty
I have a 3wh. 'LR'model Pride scooter for
I'd be looking at the motor controller first. Since you don't have any flashing leds to indicate a problem, perhaps the brushes on the motors need replacing.
Jul 28, 2017 | Pride Mobility Products Pride Mobility...
7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Jul 08, 2010 | Pride Go Go Elite Traveller Plus HD 4...
I HAVE JUST PURCHASED A 3 WHEELER MODEL PRIDE
AXLE NEEDS GREASE!!!! DO NOT RUN IT !!! WITHOUT IT,THE PLACE U BOUGHT SHOULD HAVE BUT WERE PROBABLY BEIN LAZY
Jul 15, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Ajust speed
Yes, Unfortunately it is a technical solution, the twist grip speed control is a potentiometer (variable resistor) other then limited the amount the twist grip is turned , the only other way to limit the speed is to add a fixed resistor to the "top" end of the "pot", lets say you want a 10% reduction and you have a 1000 ohm pot you would add a 100 resistor to the "top" of the pot, if it doesnt work correctly change the connection to the other endof the pot
Mar 21, 2009 | Razor E100 Electric Scooter
No reverse and lost speed
that could be that you need a new pot for spped control bar, is there any up and down movement ? if yes that could be intermittant
Regards
GeWiz.
Jan 31, 2009 | Pride Mobility Products Pride Mobility...
Health & Beauty Logo
71 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
