I have a Majestic washer Model MJ9200w insided a montana camper 2006, the washer doesn,t not spin in the wash cycle or the rinse cycl, but it spins in the spin cycle. What can I do to fix it?? thanks
The drum doesn,t turn in the wash or rinse cycle only in the spin cycle..Why???
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
jonniewalker
  • 1029 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Washer fills with water during spin cycle
Go to repairclinic.com and have model number ready. They have videos how to check it
Mar 02, 2015 | Samsung WA422PRHDWR 4.2 cu. ft Large...
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
