Question about Hitachi DZBX35A DVD Camcorder
Finding cable to go from camcorder to computer
How to
  • copman1993 Apr 13, 2009
    I need to find the cord for hitachi camcorder dz-bx35a = i also need the software. Any links for either the cord or the software. Thanks
Thanks for solution!!!!
Posted on Jan 27, 2009
I lost my cable for my camcorder JVC GR-DVL300. I want to play the mini DV cassettes on it and record them to my computer.
your best bet would be to find a frys electronics around where you live. They have a great selection of different cables for different devices. If that won't work just type in your camcorder model # on ebay and see what comes up. Good luck
Oct 09, 2015 | JVC GR-DVL300 Mini DV Digital Camcorder
Trying to find a cable for my sony hI8 model number ccd-trv68 to go from my camcorder to my computer?
This is an analog camcorder - not digital. Therefore, the only cables you can use are the RCA types for audio and composite video. The computer must have an adapter board or allow RCA inputs (analog).
Nov 13, 2010 | Sony Handycam CCD-TRV68 Camcorder
I need cable that goes from camara to computer. What is this cable called and how can I find it
These cable types will fit your camcorder.. (FireWire / DV / i.Link) You can find it in any electronic store.... good luck...
Apr 30, 2010 | Sharp Viewcam VL-Z1U Mini DV Digital...
Camcorder SONY DCR-TRV25E, COMPATIBILITY window vista
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System.
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 20, 2009 | Sony Video Cameras
Cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
Option 2:
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
Option 3:
Sep 17, 2009 | Sony DCR-TRV285E Digital-8 Digital...
I need transfer my videos to my computer
If you are looking for cables for JVC GR-D370 camcorder, then click JVC Accessories Store to see list of related accessories.
And if camcorder is different model and make, let me know to find out for you.
Thanks.
Sep 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
I can't find a cable that fits my JVC GR-D347U camcorder
How old is the camcoder?
Is it digital?
You may need a video capture card installed on your computer to transfer video to your system.
Check ebay for a "dazzle" box.....
Good luck
Jun 23, 2009 | JVC GR-D347U Camcorder
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Jun 07, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Camcorder won't connect to pc
first u change ur firewire cable then chenge you pc slot in computer try it
Feb 02, 2009 | Panasonic NV-DS38 Mini DV Digital...
Pc instollation of my camcorder
1. install the cd driver camed with your camcorder
2. use USB cable to recognize your camcorder to be use on your computer.
thats it! hope that helps!
CHARCOIS
Sep 13, 2008 | Canon MV800i Mini DV Digital Camcorder
Hitachi DZBX35A DVD Camcorder Logo
169 people viewed this question
Top Hitachi Video Cameras Experts
jamie suver
Level 1 Expert
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
