Question about Dell Inspiron 5000 Notebook
I have a dell inspiron 5000\laptop\the lefthand side of my nkeyboard isn't working . i'm using a exsternal keyborad?
The leftside of my keyboard isn't working anybody have a ansewer?
  • 1 more comment
  • john ketcham Jun 28, 2007
    whats the next step?
    LETS TRY fixing it !
  • john ketcham Jul 01, 2007
    BOGDAN! THIS IS PAINTER AGAIN, SORRY TO BOTHER YOU AGAIN BUT I COULD NOT FIND THE LETTERED SCREWS. AND THE SCREWS FOR THE FRONT ARE IN THE BACK . BUT RATHER THAN BOTHER YOU ANYMORE I THINK I 'M JUST GOING TO HAVE IT FIXED.COULD THERE BE ANOTHER CAUSE LIKE THE BIOS?
Where is the bios security chip on the Dell insprion 5000 motherboard. I took it all apart and I cant seem to locate the chip. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! anyone.
Posted on Nov 24, 2008
    Novelist:
  • 198 Answers
Hello, The keyboard is connected to the mainboard via a ribbon like connector. A keyboard is actually a matrix of contacts that are linked togheter via some 5-6 lines. If one of this lines fails (broken contact, a connector that got loose) an entire area of keys will stop to work. You may recognise connector problems of such type by looking carefully at the keys that don't work. You may find that the non working keys form lines from the top to the bottom. For example if you find that the "q" key isn't working, then the "a" and "z" and "alt" may not work as well. For "w" key, the coresponding line is "S" "x" "\" and so on. In order to fix this problem you need to dissasemble the laptop and check the connection between the keyboard and the motherboard. If you have some tools (small screwdrivers mostly) and some basic knoledge about dissasembling electronic things I will assist you through the process. Please reply back if you are willing to try to fix the laptop on your own and I will guide you through the process. Otherwise, a service center may be able to dissasemble the laptop and check that connector or the keyboard for a small fee. Please reply back when you make the decision to either repair it yourself or let a service center do the job. Good luck. Bogdan.
Posted on Jun 27, 2007
  • Motoi  Bogdan
    Motoi Bogdan Jun 29, 2007
    On the back of your laptop you should find some screws holding your keyboard fixed to the body. At most dell models each screw has it's own designation noted on the casing. For keyboard screws there should be a "W" letter next to them, for casing screws a "C" and so on. In this situation you should look for the W screws and remove them. If your laptop doesn't have this type of notation, you should try to unscrew some of them to see how they look. The longest of the screws you remove are the ones that keep the keyboard attached. Try to remove those. After you finish this, on the top side (with your keyboard) you should find a plastic part of the casing just over the keyboard near the display. It houses the power on button and everything in that area. It should be removed also. Then you can reach to the keyboard and try to remove it. You will see a ribbon like connector that runs from the keyboard to the motherboard, check that one, bend it a little and check to see the results. This should help you with the problem.
    If you need more informations about dissasembling the unit please reply. Sorry for I have'n posted sooner, I was supposed to be informed by email when you reply, but however that didn't happened.
    Good luck.
  • Motoi  Bogdan
    Motoi Bogdan Jul 02, 2007
    No, the BIOS doesn't manage this sort of things. On the contrary if the BIOS detects a major problem with the keyboard it will stop booting your laptop and give an error. These problems are only hardware based, and as you may think there isn't any reason for a software component to turn off a part of your keyboard.
What is the best SD card to use in the Dell Inspiron 15 5000 series laptop?
Dell Inspiron 15 5000 Series Specs - CNET
https://www.cnet.com/products/dell-inspiron-15-5000-series-laptop-computer.../specs/
Dell Inspiron 15 5000 Series Laptop Computer - fndnm2603sw7p Specs. Overview · Specs ... 5 in 1 (SD Card, Memory Stick, Memory Stick PRO, SDHC Card) ...
Dell 128GB Class 10 MicroSDXC Card with SD Adapter ' Dell United ...
https://www.dell.com/en-us/shop/dell-128gb-class-10...card-with-sd.../memory It can also be used in conjunction with the optional SD card adapter for standard size SDHC/SDXC host devices. ... View All Laptops; Inspiron: For Home and Home Office ..... This product is compatible with the following systems: Inspiron 15 5000 Series (5567); Inspiron 17 5000 Series (5767); Inspiron 15 5000 Series (5565) ... best SD card to use in the Dell Inspiron 15 5000 series laptop Google...
Jul 07, 2018 | Dell Computers & Internet
I have hp laptop but i cant use coz the keyborad...keyborad loose enter, backspace, letter z and h, and the arrow on the right side...my laptop is mini hp...can u help me plss....
Hey, If a few keys do not work on your keyboard you can get them replaced , i recently got my new replacement keys from www.laptopkey.com Now my laptop keyboard is as good as new. Love them for they service and reasonable cost.
Sep 06, 2011 | Compaq Keyboard
I am using Dell Inspiron 1525 Vista Home basic,64-bit Os. I am facing problem with Keyborad keys - Space bar,Arrow Keys,B and N keys are not working.Kindly suggest the solution.
Try an external keyboard and see if that works.
Device manager and find keyboard
open that up and delete standard keyboard info and hard boot
Aug 25, 2010 | Computers & Internet
I need a free manual download for the Dell
There are several manuals for Dell Inspiron 5000, You can download whatever you want from this link;
click here to open the link
Open the link, and from the "Document Title" lists, select the one you would like to download, they are only pdf files.
Or alternatively you can read all the documentation and tutorials here;
Online User Manual Dell Inspiron 5000
Good luck.
Thanks for using FixYa.
Jun 26, 2010 | Dell Inspiron 5000 Notebook
I want to install a new keyborad for dell inspiron 1420 to work as an individual one can anyone please tell me how?
The easiest way to do what you want is to buy a USB keyboard. Some Dells have ps2 connector and you might be able to use a ps2 keyboard. The ps2 connector will be on the back and is round and has holes going in a circular patterns.
Apr 25, 2010 | Dell Inspiron 1420 Laptop
On my dell inspiron 15 laptop brand new
if they are relly broken you need to buy a new keyboard. depending on the type of your inspiron you should search for a new one like this http://cgi.ebay.com/Dell-Inspiron-2600-2650-Laptop-Parts-15-Keyboard_W0QQitemZ270256807128QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3eec8f9cd8&_trksid=p3286.m20.l1116
next time you want to clean your keyborad just use compressed air out of a bottle.
Aug 05, 2009 | IBM ThinkPad T42 Notebook
Wireless keyborad
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 19, 2009 | Compaq Wireless Keyboard/Mouse p5304
Inspiron 2650 Laptop keyboard is locked.
If the keyboard is locked ALL the time, try unpluging the power supply, remove the battery, then push and hold the power button and any key on the keyboard for at least 30 seconds. then reinstall the battery, plug the pwoer cord back in and reboot it.
I had the same problem and that is what the DELL techs had me do. I had the problemm frequently for a while and then it just quit recurring. I haven't had the problem for a long time now.
I hope this helps.
Don Jones
Dec 17, 2008 | Dell Inspiron 2650 Notebook
Keyboard
I had the same problem and had to replace the keyboard
Mar 17, 2008 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Dell Inspiron 5000 Notebook Logo
83 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
