Question about Black & Decker Dewalt #D55155 2HP 4GAL Eleccompressor
Difference between dewalt d55155 type 1 and type 2
2 Suggested Answers
  • 4234 Answers
SOURCE: Dewalt D55155-QS 220 volts can it convert to use 115 volts?
The short answer unfortunately is no. The internal motor that drives this compressor requires 220 and will not work properly with 110. Your only option would be to replace the motor with one compatible with 110. The cost of that would approximate a major portion of a replacement unit.
Sorry about the bad news.
Dan
Posted on Jul 08, 2010
What type of oil to use
Use 30 wt oil and fill it up till it comes 1/2 way up in the bubble.
Mar 22, 2016 | Dewalt D55155 Emglo Air Compressor
How do i start a dewalt d55155 compressor
Its switched automatic on when the air-pressure in the tank comes to a lower level .
Other is by hand but there can be build on a circuit breaker on your type if the powercord was manual used by hand without pressure relief by switch.
Sep 10, 2014 | Dewalt D55155 Emglo Air Compressor
I have a D55151 Dewalt comp. that wont pump past 40lbs. What can couse this??
I don't what you mean by a "cold start" valve? Too much typing for a guess.
Dec 11, 2013 | Dewalt D55155 Emglo Air Compressor
I'm using my dewalt for bead blasting projects, Lately moisture is coming from the pistol
It's on the bottom, right hand side of the tank if you are facing the tank side. You can download the owners manual from this link. It is at the upper right side of the page in the section marked downloads.
DeWalt D55155 parts and owners manuals
Aug 21, 2012 | Dewalt D55155 Emglo Air Compressor
Dewalt emglo d55155 air compressor-what type of oil? this machine is electric
Need to use air compressor oil it is available at you local hardware store in the tools department.
Feb 05, 2011 | Dewalt d55151 factory reconditioned emglo...
I want to change my EMGLO D55155 compressor oil. What type and how much oil should I use? Thank you!
The compressor tanks 4 ounces of oil.
You want to use a synthetic oil in this unit. We like to use Mobil 1 full synthetic 10w30 oil.
Here is a link top the owners manual:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55155/D55155_OM.pdf
Oct 07, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Dan
Jul 08, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Dewalt D55155, I want to change oil, what type and how much do I use
use30 wt oil and fill it up till it comes 1/2 way up in the bubel
Nov 05, 2009 | Dewalt Air Tools & Compressors
Dewalt D55155 air compressor regulator installation
The d55155 unit suffers from regulator problems due to weakness in the design of the manifold. The manifold parts are very light duty metal and will break during installation if not carefull. If you can return the parts to dewalt it may be more efficient to to use a generic pressure regulator from www.grainger.com for about 20 bucks and mount using a couple of 1/4" tees directly off the pressure switch. Remove the hose from the pressure switch that feeds air to the manafold . Install parts so that the quick disconnects, guages and new regulator are accessable from the side. It will not be pretty but problem will be solved for long term. We repair other brands that come with control panels using the same method. Pressure regulators built into a manafold will fail. For demanding customers we have recreated the manafold using 1/4 pipe fittings and refit the gauges and grainger regulator into panel.(lots of work) But leave the safety unloader at the pressure switch. If all you need is a good functioning compressor same time and money and mount to side. Good Luck and email if you have questions or other issues with your dewalt.
Feb 19, 2009 | Black & Decker Dewalt #D55155 2HP 4GAL...
Black & Decker Dewalt #D55155 2HP 4GAL Eleccompressor Logo
169 people viewed this question
Top Black & Decker Air Tools & Compressors Experts
John Trevino
Wayne Fellows
Wayne Fellows
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Black & Decker Air Tool and Compressor Expert? Answer questions, earn points and help others
